4 members (55shaker, Shade Baby, GMCJammer51, joe apple), 86 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
I'm looking for the original equipment spare tire mounting hardware. Under the bed. I've got a '62 short stepside and don't want to mount it on the inside of the bed or even carry it in the bed. I've checked LMC and Jim Carter. . . no luck. You guys got any ideas?
Thanks!
Doug Robertson
Purcellville, VA
1962 C10 shortbed
Doug,
Hit Leon's just south of culpepper and grab one from the yard. If not Leon's then your other local junk yard. Will be much easier on the wallet to buy from a local yard then the one currently on ebay.
They were the same for many years. I think 55.2-66 will be about the same.
You likely will have to cut off the bolt so bring a hack saw. Replace the bolt later. If you need original nut/bolt once you find the bracket then call on me. I collected 1 or 2.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks Hambone!
1962 C10 shortbed
Socket Breaker
Socket Breaker
a lot of the vendors sell nos/used parts, but they don't always keep an accurate list on their websites, so you might have to use the pesky telephone and like, call and ask.
stovebolt links / parts vendors section
-W
PM sent
1959 3100 Apache Fleetside
Originally Posted by Hambone
Doug,
HB
60-62 frame rails are wider at the back than 63-66 and the tire mount runs from frame rail to frame rail
ron
That is good reminder. Ihad forgotten. I believe the bar (bracket) has multiple hole options to accomidate multiple years. Maybe you can confirm that for me.
~ HB
1962 Chevrolet C10
1962 Suburban
