2 members (fonz8261, HandyAndy),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 13 New Guy | | New Guy Joined: Mar 2017 Posts: 13 | I'm looking for the original equipment spare tire mounting hardware. Under the bed. I've got a '62 short stepside and don't want to mount it on the inside of the bed or even carry it in the bed. I've checked LMC and Jim Carter. . . no luck. You guys got any ideas?
Thanks! Doug Robertson Purcellville, VA
1962 C10 shortbed
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Doug,
Hit Leon's just south of culpepper and grab one from the yard. If not Leon's then your other local junk yard. Will be much easier on the wallet to buy from a local yard then the one currently on ebay. They were the same for many years. I think 55.2-66 will be about the same. You likely will have to cut off the bolt so bring a hack saw. Replace the bolt later. If you need original nut/bolt once you find the bracket then call on me. I collected 1 or 2. HB | | | | | Joined: Mar 2017 Posts: 13 New Guy | | New Guy Joined: Mar 2017 Posts: 13 |
1962 C10 shortbed
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | a lot of the vendors sell nos/used parts, but they don't always keep an accurate list on their websites, so you might have to use the pesky telephone and like, call and ask. stovebolt links / parts vendors section -W | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 |
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Doug,
Hit Leon's just south of culpepper and grab one from the yard. If not Leon's then your other local junk yard. Will be much easier on the wallet to buy from a local yard then the one currently on ebay. They were the same for many years. I think 55.2-66 will be about the same. You likely will have to cut off the bolt so bring a hack saw. Replace the bolt later. If you need original nut/bolt once you find the bracket then call on me. I collected 1 or 2. HB 60-62 frame rails are wider at the back than 63-66 and the tire mount runs from frame rail to frame rail ron | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | That is good reminder. Ihad forgotten. I believe the bar (bracket) has multiple hole options to accomidate multiple years. Maybe you can confirm that for me.
