11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Having trouble with the rebuild. As you can see in this pic, the silver can is barely held in by the two screws and the spring on the bottom. Think I am missing something? image
Thanks Denis Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | those screws should be headlight adjusting screws. link
| | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | Those adjusting screws (as Jim said) should probably engage the headlight can a bit more. The can slides around in the bucket so maybe it's just been pushed out of position. You should be able to push it back into position so the screws stay engaged. The slots should probably be bent slightly upward so the screws stay engaged in the slot.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think the "white" can is rotated wrong. Those small screws are not the adjusting screws but holds the silver white bucket in place. There are two other screws that, in conjunction with a spring, that is the adjuster. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Its been a few years since I put mine together so my memory may be wrong. I thought the adjusting screws were located 90 degrees from each other to allow left-right and up-down adjustment. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Take the white part off and look for a coil spring. If that is missing you may be dead in the water. It looks like you are missing the adjuster screw assemblies (there are 2 of them for up and down, and left and right).
| | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | The other guys are correct, The adjustment screws seem to be missing. Here are a couple of pics showing the adjustment screw mounts on the bucket and the location of the spring (which is riveted to the bucket) near the bottom. Headlight bucketAdjusting springUnfortunately the adjustment screws I took out of the bucket are "filed away" (probably in a box that I can't quite reach), but they have a nylon block that clips into the metal bracket shown in the first pic.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Thanks all, I do have the adjusting screws in. Also the spring is attached. The challenge seems to be the back of the silver can does not sit into the housing to the point the adjusting screws engage. Can anyone describe how the adjusting screws are supposed to engage the can and make it move? As mine is now, the nut is in the frame the the screw is perpendicular. One can ether screw in our out but I don't see what it moves?
| | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | When you say "slot" you mean where the sheet metal screws grab the can?
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | OK 47-53 headlight bucket. http://s1276.photobucket.com/user/jsdesign2/library/Chrome ring mounting screw at 6 o'clock adjusters at 9 and 12 1 spring vertical ridges on the moveable piece run against the center edge of the back bucket No way you can screw the center piece down flush. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You have the "Body" the black part screwed to the Fender and then the "Mounting Ring" (silver dish part) screwed to the Body, that's the problem. The Mounting Ring is supported off of the Body with the two adjusting screws, not screwed tight to the Body. The Adjusting Screws are located at 12 and 9 o-clock and the spring is at 5 o-clock. The screw slots in the Mounting Ring (silver dish) get inserted into the groove on the head of the adjusting screws. Hope this helps, Mike B  | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I correct my statement that the retainer can't be screwed down flush with the bucket. In the picture on the first post, you can see the 3 channels radiating out from the center, that are pressed into the retainer. These create ridges on the back that ride on the center edge of the bucket, allowing the retainer to rotate when the retaining screws are adjusted. If you look at the one that runs down from about 1 O'clock, you will see a crease pressed into it from the back when the retainer was screwed down to the bucket. These (on the others too) will cause problems with adjusting when the assembly is put together correctly unless they are hammered out. | | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | I correct my statement that the retainer can't be screwed down flush with the bucket. In the picture on the first post, you can see the 3 channels radiating out from the center, that are pressed into the retainer. These create ridges on the back that ride on the center edge of the bucket, allowing the retainer to rotate when the retaining screws are adjusted. If you look at the one that runs down from about 1 O'clock, you will see a crease pressed into it from the back when the retainer was screwed down to the bucket. These (on the others too) will cause problems with adjusting when the assembly is put together correctly unless they are hammered out. I agree completely with Jim's statement. The can needs to move freely within the bucket, and those dents in the radial channels would prevent that. The way the adjusting screws work is when tightened, the spring lengthens and vice-versa, while the can rotates within the bucket, changing the point of aim of the headlight. As you can see on the photo I posted, there are two holes near the spring. The one on the right allows the adjusting screws to line up with the notches on the can. If the spring is hooked in the left hole, the adjusters won't line up. I seem to recall that the adjusters were a bit of a task to get out. I think they insert from the outside of the bracket toward the center. Is it possible you have them inserted in the brackets in the bucket backward? That might put them too close to the center of the assembly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Figured it out thanks everyone
