| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 13 New Guy | | New Guy Joined: Mar 2017 Posts: 13 | Well, my 2nd and 3rd synchros are shot in my original 1962 3 speed. Haven't found replacements yet. I'm considering replacing the entire tranny with another 3 speed. Any suggestions? I need advice please. Thanks guys Doug Robertson Purcellville VA
1962 C10 shortbed
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you are happy with the way the tranny was before it gave problems I'd go for rebuilding what you have. Finding a replacement may be easy but how long will it last before you have problems with it. If you don't feel good about doing the work ask around and find someone who does and have them to it. New gears/bearings/seals and you'll be surprised how quite your truck just became!
Now if you find a used one on the "cheap" maybe do the swap while building yours.....and, the used one may have a different "ratio" than the one you have and are happy with? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Get a t5 5 speed you will really enjoy driving the truck then.Yes, it is a little more shifting, but the drop between the gears is less and the truck becomes so much more responsive it seems like a new truck. Look for Lugnutz on here, he can help with any questions you may have.You will also have a more modern transmission and overdrive if you use the highway.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You may also try to find a Saganaw 3 speed which was available on later cars & trucks. They are full syncro units and can be identified by the 7 bolt side cover. You will need to do some modifications to the shift arms and change the front drive shaft yoke. They are good transmissions and seem to be more available and reasonably priced. Fred
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Well, my 2nd and 3rd synchros are shot in my original 1962 3 speed. Haven't found replacements yet. I'm considering replacing the entire tranny with another 3 speed. Any suggestions? I need advice please. Thanks guys Doug Robertson Purcellville VA Tommy suggested a T5 transmission. If you lean that direction, I have a very good friend who lives in Stephens City, VA. He has a T5 we installed in his 1966 1/2 ton. I'm sure he'd let you take a test drive to see what it can do. Let me know and I'll get you in contact with him.
| | | | | Joined: Mar 2017 Posts: 13 New Guy | | New Guy Joined: Mar 2017 Posts: 13 | You guys are great! I went with Hambone's suggestion and visited Leon's salvage in Culpeper, VA and got a Saginaw 3 sp. I agree the T5 would probably perform better, but I've got a 3 on the tree and want to try and keep it as close to original as possible. Anyway, it's still at the shop waiting install. Argh! Eager to try it out! Thanks! Doug
1962 C10 shortbed
| | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I have mine setup for 3 on the tree and love it. I sort of like the old school...
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
