BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
7 members (JW51, Hotrod Lincoln, cmayna, Guitplayer, Possum, Joe W, UtahYork),
514
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2017 Posts: 299 'Bolter | 'Bolter Joined: Mar 2017 Posts: 299 | I can't make up my mind on this. Should I replace my gas tank to it's original spot behind the seat or replace it with a tank mounted underneath the truck box between the frame? It just seems that it would be safer to mount one between the frame. Than to put it in the cab behind the seat. What are your thoughts? | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Does anyone know of fuel tank in the cab exploding or causing a fire? | | | | Joined: Apr 2005 Posts: 7,442 Bolter | Bolter Joined: Apr 2005 Posts: 7,442 |
| | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | Shop Shark Joined: Jun 2011 Posts: 1,901 | Its not like it's a Pinto. What does Google say?
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | | | | | Joined: Mar 2017 Posts: 299 'Bolter | 'Bolter Joined: Mar 2017 Posts: 299 | Thanks for the excellent article from Jim Carter!! I guess that answered my question!!!! | | | | Joined: Apr 2016 Posts: 941 'Bolter | 'Bolter Joined: Apr 2016 Posts: 941 | I have been asking myself the same question. If I move it where do I put my spare tire?
| | | | Joined: Mar 2010 Posts: 10,059 Renaissance Man | Renaissance Man Joined: Mar 2010 Posts: 10,059 | Anywhere but under the bed would be a better place to put the spare tire. The reason those carriers are so rare is that they likely got left in the ditch after the very first flat tire.
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | ?????
I do not understand: "If I move it where do I put my spare tire?"
In 1953, put it under the bed, or on the bedside, depending on your model truck.
| | | | Joined: Apr 2016 Posts: 941 'Bolter | 'Bolter Joined: Apr 2016 Posts: 941 | Mine is still there and doesn't even have a tire on it since 1980.
