1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1217213 05/14/2017 12:50 PM
I can't make up my mind on this. Should I replace my gas tank to it's original spot behind the seat or replace it with a tank mounted underneath the truck box between the frame? It just seems that it would be safer to mount one between the frame. Than to put it in the cab behind the seat. What are your thoughts?
Does anyone know of fuel tank in the cab exploding or causing a fire?
Rare event if ever!
Its not like it's a Pinto.
What does Google say?
Give me ambiguity
or give me something else
from Jim Carter: gas tank location
But, panel body truck still needed to place the fuel tank under the body, between the frame rails, and forward of the rear-end (as done in 1947 A-D standard-cab trucks).
Thanks for the excellent article from Jim Carter!! I guess that answered my question!!!!
Elmo #1217449 05/16/2017 12:10 AM
I have been asking myself the same question. If I move it where do I put my spare tire?
Anywhere but under the bed would be a better place to put the spare tire. The reason those carriers are so rare is that they likely got left in the ditch after the very first flat tire.
I do not understand: "If I move it where do I put my spare tire?"
In 1953, put it under the bed, or on the bedside, depending on your model truck.
Mine is still there and doesn't even have a tire on it since 1980.
