| | | Forums66 Topics128,179 Posts1,057,134 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | Nice info, thanks.
I like the heater as it is funky and weird and will not be driving in the snow... Down the road when I yank that puppy out, I will have to let people know.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you find the info somewhere on the unit please post it as a follow-up. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Crusty is very accurate... | | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | Thanks for posting the crusty heater... Now I have an idea of what I will be digging into without digging into it! | | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | if you want more pictures let me know. | | | | | Joined: Apr 2016 Posts: 1,052 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,052 | I have a 6 volt heater and am running a 12 volt system, I ran a resister wire type voltage reducer. I live in Indiana and it has worked for many years. Don't use this type for gauges.
| | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | I was planning on using one for my gauges, What is the problem with them? | | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | No problem with mine that I know of, but I am new to the truck ...
the heater is not connected (electrical or plumbing) and that is most likely due to the 12volt conversion (I hope) ... I need to yank it and test it. If Motor still good, then will have to step down the voltage or get a 12 volt motor....
Then again it could just leak or leak and have a fried motor or ....... another mystery to solve. | | |
