7 members (frogfarmer, rfs56trk, 50Chevy3100, Buckeye998, JoergK., ShopRag, Lightholder's Dad), 361 guests, and 3 robots.
Topics128,160
Posts1,057,054
Members48,463
1954 3100, converted to 12 volt- heater fan was not just wondering if anybody can recognize it before I pull it out to see what is wrong
https://goo.gl/photos/eaKQtVRrR3GuDxux7
https://goo.gl/photos/fmn1TnanR3ZBpwTE7
The fan directly behind the box, picture taken from floor looking up
https://goo.gl/photos/RZsqepkHfM6zPwqy9
1954 Std Cab 3100 w/ 2 spare Engines
IL
1954 three window 3100
It is an aftermarket heater (not sure exactly which brand). There were numerous options available back then, Firestone, B.F. Goodrich, Arvin, Montgomery-Wards (Sears), etc.
https://www.flickr.com/photos/advance-design_parts_co/8377841188/in/album-72157631868452754/
The two standard heaters available from GM in '54 were versions of these.
https://www.flickr.com/photos/advance-design_parts_co/8129448404/in/album-72157631868452754/
The 53-55 1st Series Air-Flow differs in that they have a door as shown here.
https://www.flickr.com/photos/advance-design_parts_co/8129313579/in/album-72157631868452754/
Nice info, thanks.
I like the heater as it is funky and weird and will not be driving in the snow... Down the road when I yank that puppy out, I will have to let people know.
IL
If you find the info somewhere on the unit please post it as a follow-up.
I have one just like it that I pulled out of a parts truck. Well, just a bit more crusty than yours.
I apologize in advance for using photobucket. I need to switch to something else.
http://s1003.photobucket.com/user/callmedh/library/other%20heater
Crusty is very accurate...
Thanks for posting the crusty heater... Now I have an idea of what I will be digging into without digging into it!
IL
if you want more pictures let me know.
I have a 6 volt heater and am running a 12 volt system, I ran a resister wire type voltage reducer. I live in Indiana and it has worked for many years. Don't use this type for gauges.
I was planning on using one for my gauges, What is the problem with them?
No problem with mine that I know of, but I am new to the truck ...
the heater is not connected (electrical or plumbing) and that is most likely due to the 12volt conversion (I hope) ... I need to yank it and test it. If Motor still good, then will have to step down the voltage or get a 12 volt motor....
Then again it could just leak or leak and have a fried motor or ....... another mystery to solve.
IL
Moderated by  ndkid275, Phak1
