9 members (frogfarmer, baldeagle, 78buckshot, TUTS 59, klhansen, 1955 1 Series, MNSmith, Hotrod Lincoln, 1 invisible),
47
Mod | | | Forums66 Topics128,005 Posts1,055,258 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 5 New Guy | | New Guy Joined: Sep 2009 Posts: 5 | Can any one tell me how or wat to use to repair cracks in my steering wheel and wat paint is best to use. | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | As per recommendations on here, I hand sanded with 150x, blew all the cracks out with a blow gun, and filled each and every crack, a few at a time, with clear epoxy (like the syringe type). Few days drying/curing time, go back and sand the cracks with 150x or 180x. Once all of them were done, spray primed it with hi-build spray can primer, lightly sanded again, spray painted it with Krylon. Came out exceptionally well.
A repro wheel is $300, sending yours off for restoring is at least that.
I did mine as I was working on my cab interior. Waiting on paint to dry, or body filler, or seam sealer to dry, I would do 3 or 4 of the cracks on my wheel, put it aside for a few days, and then do some more. I am really satisfied with how well it came out.
Mike
Mike
1951 3100 5 window
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Will be doing mine soon--it is now light gray like the interior, want to do black like yours what type black did you use? Satin? Thanks Bill | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | I used JB Weld in the cracks, then used spray paint made for appliances from the local ACE Hardware. Mine is gloss black, the appliance paint is a epoxy type and has held up well. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I did a steering wheel 35 years ago by opening all of the small crack with a hack saw blade. Then filled them with Bondo, sanded smooth and painted it with rattle can spray paint and it still looks good! Mike B  | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I like Mike's idea for using Bondo. It is about the same density of the original steering wheel, has great adhesive characteristics on clean surfaces, and has some flex to it. The problem that I have had with J B weld is that it is extremely hard, making feathering it in with the steering wheel difficult and it cracked soon after a few musclebound turns of the wheel. I'll be giving Bondo a go on the next one I do.
| | | | | Joined: Jul 2004 Posts: 2,986 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,986 | My wheel wasn't cracked, but the finish had worn off, so my hands got black whenever I drove it. I cleaned it up good and gave it a couple coats with a rattle can. Not sure what I used without going out there and looking, but I believe it was Rustoleum. I only did it last year, but so far it's still looking great. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I like Mike's idea for using Bondo. It is about the same density of the original steering wheel, has great adhesive characteristics on clean surfaces, and has some flex to it. The problem that I have had with J B weld is that it is extremely hard, making feathering it in with the steering wheel difficult and it cracked soon after a few musclebound turns of the wheel. I'll be giving Bondo a go on the next one I do. I didn't like the idea of a very hard product like JB weld or bondo serving as the filler in the cracks/gaps when I did mine. I reasoned the vibration and flex would just repeat where the rigid meets the flexible. I used 3M panel adhesive instead. It is much closer to the rubberized material I found while opening up the cracks on mine. It sands much more like the original material.
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I have used the 3M panel adhesive on the beltline pinch weld on the back of my cab and it is a great product, but man is that stuff expensive.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | To true. the 4oz tubes are not bad tho. plus they have screw on caps for individual mix like JB weld, as opposed to the side by side special gun types in the larger sizes. But that stuff sticks!
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Were do you find the 4 oz tubes?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Sorry I missed the ?... I used these... 2oz tubes 2oz tubes of 3M panel bond adhesive
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That product looks interesting, CASO.
How sandable is it?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Sands like the steering wheel... I found it very sand able. Balsam grade softwood comes to mind. link to my steering wheel photos
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Looks real good, CASO
Nice pictures - thanks for posting them. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | CASO, I like the idea that 3M is rubberized. When I did my wheel a few years ago I think I used JB and it was difficult to sand. Time will tell if it starts to crack. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Thanks Guy's. 53- I knew I wasn't into sanding down JB weld so started looking for options from my shelf of leftovers. I am curious how it compares over time but expect to remain in mystery about that. You think folks will post if their repairs start to develop new cracks?
