1 members (klhansen), 65 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#121386 07/26/2006 8:46 PM
I have not been one to do much "body work" so I need help on a thing or two. I have glass beaded the hood latch on the panel but don't think it will look good or original looking if its painted. Soooo, isn't there a cadium paint or something that you can spray them with to keep the original looking color. I think I have seen this somewhere. (probably Eastwood but the $$ is high)My question is just exactly what is the color you get?? Or do you just spray what it is with clear, which I have never done. I think the same thing goes for the hood hinges. I want to put something on these things so they won't rust or tarnish in a month or two!
Anonymous
Unregistered
Anonymous
Unregistered
I painted mine the same as the body color.
The hinges and latch were dipped in a phosphate solution from the factory. If originality is what you're after, spray em with clear lacquer.
You can buy the paint you referred to from Eastwoods.
www.eastwoodco.com
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I am going through the same thing. I have been told that the hinges, latch plate, etc. were cadmium plated but its nearly impossible to find people who will do it because of environmental hazards. I first tried using Eastwood's silver colored carb paint as I had some already and its pretty tough stuff. The hinges looked good but I am a perfectionist and blasted that back off and tried Eastwood's cadmium paint. It looks about the same but in all actuality, I thought the carb paint looked better. I am still undecided as to which way to go.
Look around for a cad and zinc plater in your area. I have one near me that does it for super cheap. It doesn't cost anywhere near as much as chrome plating.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
I ask a local Mopar Restoration shop that does a LOT of restorations but only on Mopar. He suggest I use a couple coats of self etching primer out of a spray can, then buy a good can of the Hammer Finish Stainless spray can. He says it may not be "original" but would look good. I think that is what I will try and if it don't look good or suit me I will bead blast it back off and start over......maybe I can find a zinc or cad plater. Let you know by the weekend if I like the "hammer stainless".
