4 members (tesa, baldeagle, pdlightning, walter74), 347 guests, and 3 robots.
Topics128,166
Posts1,057,092
Members48,463
I've been collecting parts for a 1957 GMC 250 panel project. The gas tank on the truck needs to be replaced.
Any thoughts on where to find a replacement gas tank and sending unit?
Matt
Big Bolt Forum Moderator
when I had my 59 Suburban, I ended up buying a sending unit for a pickup and using parts of it to repair my original one. You might try a universal/adjustable one, http://www.americanclassic.com/ has some that may work. They only fit in one way and are a pain to get exactly right. As far as the tank, I have not seen direct replacements but, I did not look very hard as mine was fine.
Mike
I've been shopping for a new tank as well, so if you find a source for your TF panel post it here, they may have AD underfloor tanks. I've gone to several shops and asked what other years/models/makes will fit, nobody has a clue. Apparently, you can't just give the dimensions, capacity, and porting requirements to find a similar tank. Not sure why this is, probably has to do with Google replacing the pre-frontal cortex of today's mechanic. Short of having my tank purged and welded the most cost-effective option I've run across are plastic marine-application fuel tanks and fabricating my own straps.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
I
I Offline
I scoured the internet for over a year, never did find a suitable replacement.
Wound up having my tank split, loose baffle welded back in place, dents pounded out, and the inside epoxy coated for @ $500. Worth every penny of it. It's original, will outlast me, and I didn't have to play around with fitting a different tank.
I found a suburban/panel sending unit at Jim's.
idaho
There is a local Phoenix AZ shop called Custom made gas tanks.I' m certain you could find such a place closer by.Got a dented,leaking and goo-sealed 58 panel tank that I dont want to bother to save.
The guy doesnt do contoured corners,just normal bends,so I compensated by gradually lengthening/bending (in a staircase step fashion) to get around the curved frame support members. His quote was just about what a universal would cost.
Then I added an additional 6 inches on front and
rear to make up for the loss.But it will still be just a few gallons more than the stock 10 gallon tank.Also gonna add a 3/8 return nipple for a wix regulated filter.
Sorry Matt,didn't realize you were the OP...
I dont know how any sending unit is gonna give me an acurate reading,but the OEM guage cant be trusted anyway..drive/refill...repeat
