2 members (Frank50, Joe H),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I've been collecting parts for a 1957 GMC 250 panel project. The gas tank on the truck needs to be replaced.
Any thoughts on where to find a replacement gas tank and sending unit?
Matt | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | when I had my 59 Suburban, I ended up buying a sending unit for a pickup and using parts of it to repair my original one. You might try a universal/adjustable one, http://www.americanclassic.com/ has some that may work. They only fit in one way and are a pain to get exactly right. As far as the tank, I have not seen direct replacements but, I did not look very hard as mine was fine. | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I've been shopping for a new tank as well, so if you find a source for your TF panel post it here, they may have AD underfloor tanks. I've gone to several shops and asked what other years/models/makes will fit, nobody has a clue. Apparently, you can't just give the dimensions, capacity, and porting requirements to find a similar tank. Not sure why this is, probably has to do with Google replacing the pre-frontal cortex of today's mechanic. Short of having my tank purged and welded the most cost-effective option I've run across are plastic marine-application fuel tanks and fabricating my own straps. | | | | | Joined: Jul 2010 Posts: 6 New Guy | | New Guy Joined: Jul 2010 Posts: 6 | I scoured the internet for over a year, never did find a suitable replacement. Wound up having my tank split, loose baffle welded back in place, dents pounded out, and the inside epoxy coated for @ $500. Worth every penny of it. It's original, will outlast me, and I didn't have to play around with fitting a different tank. I found a suburban/panel sending unit at Jim's.
idaho
| | | | | Joined: Mar 2017 Posts: 18 New Guy | | New Guy Joined: Mar 2017 Posts: 18 | There is a local Phoenix AZ shop called Custom made gas tanks.I' m certain you could find such a place closer by.Got a dented,leaking and goo-sealed 58 panel tank that I dont want to bother to save. The guy doesnt do contoured corners,just normal bends,so I compensated by gradually lengthening/bending (in a staircase step fashion) to get around the curved frame support members. His quote was just about what a universal would cost. Then I added an additional 6 inches on front and rear to make up for the loss.But it will still be just a few gallons more than the stock 10 gallon tank.Also gonna add a 3/8 return nipple for a wix regulated filter. Sorry Matt,didn't realize you were the OP... I dont know how any sending unit is gonna give me an acurate reading,but the OEM guage cant be trusted anyway..drive/refill...repeat
