1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1211992 04/07/2017 3:38 AM
My truck is missing the reverse lockout linkage between the finger lever and the transmission. There was just a piece of wire tied to the plunger near the transmission lever. Also it looks like there is a spring in the pivot of the finger lever, which I think it's broken. Does anyone have some pictures of how the finger lever is connected to the transmission on a cabover?
Is the spring even available? Is the linkage available anywhere?
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
H Online: Content
I've got a couple of those transmissions with the linkage intact. It should be a very simple part to fabricate if necessary. Once it's daylight I'll snap a few pictures. PM an email address to me and I'll forward some pics. No help on a cabover, sorry!
Farmdog,
Jim Carter had those springs a few months ago. It seems all the transmissions with the reverse lockout have broken springs and the vendors get back ordered on them. It can be confusing to figure out the orientation when you replace it, so pay attention to what you got now. I can email you a picture of the proper orientation if necessary.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
In the COE, the shift lever is not right on the transmission. The reverse lockout must have some sort of connection to the transmission, but I don't know how it's set up. Is it a cable, rods, etc?
I'm assuming I will have to fabricate something, I would like to know which way was original.
1962 IH Scout 80
Crusing in the Passing Lane
It is a formed rod, either piano wire or something like that, not just straight.
Ed
Stephen, I have a 42 COE and I believe it still has the shifter. I'll check tonight and see if it is in tact. If so, I will pull it off and snap some pictures.
Am I to assume that you have a first design COE, not an advance design? If so, do you have any idea if you have an GKT 134 transmission or an SM 420? Maybe someone else can chime in on which transmission would be standard. I'm fairly certain that 46 was a cross over year for transmissions in the big trucks....
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
Stephen,
It looks like a cable connection. I have added some photos here
http://s1006.photobucket.com/user/rrdomeck/library/1941%20COE%20Chevy?sort=3&page=1
Let me know know if you need any other photo's. I could probably pull these parts off and duplicate them, but it would be a little while before that could happen as my business is swamped at the moment!
Good luck,
Randy Domeck
[email protected]
317-258-0039
Thanks Randy,
I'll look those over when I get home.
1962 IH Scout 80
I think I understand now. I've only seen glimpses of a cable before, but I think I can fabricate a linkage now.
1962 IH Scout 80
Let me know if you need any other pictures.
Randy Domeck
[email protected]
317-258-0039
My little brother found me a NOS one still in the box. There is no spring, just like a choke cable mounted on the shifter stem of the trans.. A clip holding the cable on the side of the shifter and the end of the cable hooked to the lever under the shifter knob.
