4 members (klhansen, Ribside, greenie-reddy, 1 invisible), 92 guests, and 2 robots.
Topics128,261
Posts1,058,323
Members48,485
#1211781 04/05/2017 8:18 PM
I have a 1949 Chevy 3800 and I have an issue with gear lube leaking out the driver side of the axle hub. When the wheel is on the fluid runs down and behind the wheel. As of right now I have the wheel and drum off the driver side. I don't know if there is a seal on that side of the axle that is bad and I need to replace or what. If anyone has any ideas or information about this, that would be really helpful.
Riding in the Passing Lane
Yes. There is a seal in the hub. You need to pull the hub/drum off to replace it. Read up on pulling the hub. There has been plenty of talk on this website about it. Do a search. Find repair manual & read up. This is not for the faint of heart. If not done right severe damage to the axle & hub will result.
1972 Chevy c10 Cheyenne Super
Could you help me find a search that could aid me in this?
Probably best to get a service manual.but in the meantime go on you tube and search out 1953 hub removal.just saw a video there that will show you what you need to do. Not too bad.
1949 gmc 1-ton
Good info, hopefully mine doesn't leak, was going to replace when swapping rear end but could not locate seal to fit my 51.
51 1 ton Panel
Betty, she's a handful
That's when mine started to leak. When I but a new ring and pinion set to make my truck go a bit quicker. And for me it's just the driver side. And thank you to all who have helped me this was really helpful!!
Best of luck!
