| | | Forums66 Topics128,261 Posts1,058,327 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 12 New Guy | | New Guy Joined: Sep 2015 Posts: 12 | I have a 1949 Chevy 3800 and I have an issue with gear lube leaking out the driver side of the axle hub. When the wheel is on the fluid runs down and behind the wheel. As of right now I have the wheel and drum off the driver side. I don't know if there is a seal on that side of the axle that is bad and I need to replace or what. If anyone has any ideas or information about this, that would be really helpful. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes. There is a seal in the hub. You need to pull the hub/drum off to replace it. Read up on pulling the hub. There has been plenty of talk on this website about it. Do a search. Find repair manual & read up. This is not for the faint of heart. If not done right severe damage to the axle & hub will result. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2015 Posts: 12 New Guy | | New Guy Joined: Sep 2015 Posts: 12 | Could you help me find a search that could aid me in this? | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Probably best to get a service manual.but in the meantime go on you tube and search out 1953 hub removal.just saw a video there that will show you what you need to do. Not too bad. 1949 gmc 1-ton | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Good info, hopefully mine doesn't leak, was going to replace when swapping rear end but could not locate seal to fit my 51. | | | | | Joined: Sep 2015 Posts: 12 New Guy | | New Guy Joined: Sep 2015 Posts: 12 | That's when mine started to leak. When I but a new ring and pinion set to make my truck go a bit quicker. And for me it's just the driver side. And thank you to all who have helped me this was really helpful!!
Best of luck!
