2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
1 Offline
Hello,
I purchased a new clutch kit (Luk) from Napa which includes a new pressure plate.
Should the pressure plate have a ground surface? The one I received has a very rough surface with the tool marks from turning it very evident. Images are below.
http://s1285.photobucket.com/user/1866yellowboy/library/pressure%20plate%20clutch
Any help would be appreciated. Thanks
Looks normal to me. The disc will polish it smooth after some use.
drive
How deep are those grooves?
H Online: Content
I've seen better, but that one will smooth out pretty quickly as the disc wears in. You might have to adjust it a few times before the pedal height and free pedal stabilizes.
1 Offline
Thanks guys. I appreciate the feedback. I have never installed or seen a new one and wanted to make sure it was normal before putting it together. Sounds like this one is good.
I am not sure how deep the grooves are 52Carl you can easily feel them with your finger for sure. I am going to put it together and move on.
H Online: Content
Be sure to get the flywheel resurfaced if there's any glazing, or the pressure plate will be carrying most of the driving torque while the flywheel side gets little, if any traction.
1 Offline
Thanks for the tip Jerry. I dropped the flywheel off with the engine at the machine shop and they are going to resurface it.
Q
Q Offline
Wow that's a rough finish! Personally I would not use it. I'd take it back and get a different one,check it and make sure it has a better finish. It is normal to see the machining but it should be a finer cut. I would be concerned about premature disc wear because of the course and deep cut. Just my professional opinion.
Agree with taking it back. It should at least be smooth enough that you can't catch a fingernail run across it. Doesn't have to be glassy smooth, but something that rough is going to wear a significant portion off the disk on break-in. JMO.
