0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Hello, I purchased a new clutch kit (Luk) from Napa which includes a new pressure plate. Should the pressure plate have a ground surface? The one I received has a very rough surface with the tool marks from turning it very evident. Images are below. http://s1285.photobucket.com/user/1866yellowboy/library/pressure%20plate%20clutchAny help would be appreciated. Thanks | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Looks normal to me. The disc will polish it smooth after some use.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | How deep are those grooves?
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I've seen better, but that one will smooth out pretty quickly as the disc wears in. You might have to adjust it a few times before the pedal height and free pedal stabilizes. Jerry
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Thanks guys. I appreciate the feedback. I have never installed or seen a new one and wanted to make sure it was normal before putting it together. Sounds like this one is good.
I am not sure how deep the grooves are 52Carl you can easily feel them with your finger for sure. I am going to put it together and move on.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Be sure to get the flywheel resurfaced if there's any glazing, or the pressure plate will be carrying most of the driving torque while the flywheel side gets little, if any traction. Jerry
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Thanks for the tip Jerry. I dropped the flywheel off with the engine at the machine shop and they are going to resurface it. | | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | Wow that's a rough finish! Personally I would not use it. I'd take it back and get a different one,check it and make sure it has a better finish. It is normal to see the machining but it should be a finer cut. I would be concerned about premature disc wear because of the course and deep cut. Just my professional opinion. | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Agree with taking it back. It should at least be smooth enough that you can't catch a fingernail run across it. Doesn't have to be glassy smooth, but something that rough is going to wear a significant portion off the disk on break-in. JMO.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
