8 members (1955 1 Series, jkreiner, greenie-reddy, 2-Ton, Ribside, Jay R, Gdads51, Otto Skorzeny),
198
Mod | | | Forums66 Topics128,251 Posts1,057,951 Members48,477 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | 1961 apache. front end is off. I saw 58 chrome headliet bezels for sale. will they bolt to my 61 grill. they look? the same.
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | last nite took seat out, disconnect small things from cab. some floor rot to address. next step cab off frame
1961 apache
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Don't think the bezels are the same.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | im guna get a beatup bezel off e bay, bolt holes look darn close lol
1961 apache
1961 apache
| | | | | Joined: Mar 2014 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 92 | PM sent. I think I know of one. Thanks JP | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | last nite I got all the cab bolts off. got lucky! next is steering colom. im guna try to take the cab off the frame, that's the plan, lol. more to cont......
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | 00P0P_ho0ebnK11nf_600x450[1
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | got the steering wheel/Colum out this week end
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | removed fuel tank( great shape) got the cab on 2x4's. cant move it yet, motor in the way. starting to remove the bed.
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | removing paint on the part of the grill in front of the rad. sprayed bed bolts. found some ideas for brake/clutch issue. ccp has a nice combo with booster and pedels!
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | this is wat she looked like wen I got her pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | this is how she sits now. not much dun this weekend pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | don't know if im in the rite spot, doing this rite? anyway more progress pikup
1961 apache
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Chaz, you just keep adding to a post about grills. The best thing to do if your intention is to document your progress/build is to start a thread in the Project Journal Forum or the DIYT Sub-Forum in the welcome center. This will get you more exposure. If you have a specific question about a certain item or task then post that question in the appropriate forum for that item or task. Hope this helps.
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | got the bed pulled back, removing cab will be nxt pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | REMOVED CAB LAST NITE pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | a little start on some small pieces pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | finial got things moved around, also some new parts pikup pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | workin on pass side, rocker removed pikup pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | this is the only bad floor brace, starting to remove pikup
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | well not so much workin on the apache this weekend, granddaughter b day party then onto getting new glasses. then back to work. dosent time fly !!!
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup pikup had the day off. front brace is shot. removed it. some of the floor is bad 2nd pic, started removing it
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup pikup fitting new panels in
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | big snow storm! new phone( pain in the neck trying to figure out) anyway... GOT THE NEW INNER ROCKER/FLOOR in.trying to keep as much old floor as possible, most of it is good. also installed fron floor brace. pics will come as soon as photobuket behaves. lol
1961 apache
1961 apache
| | | | | Joined: Jan 2002 Posts: 2,848 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,848 | And here I was hoping we were talking about grilling a couple flank steaks with cherry wood, etc.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | lol these are harder to chew. but! I did score a complete grill inner/ outer headlite bezels, hood eyebrow inserts, all in chrome!!! will show pics wen ups delivers.
1961 apache
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Man, some guys have all the luck! Congrats.
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup you can see in the older pics the bottom was shot. getting closer to the rocker panel inst....
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup what a score! my front end is dun.whole pacage on ebay.
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup pikup mocking up the rocker panel
1961 apache
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Slowly but surely. Nice job. Thanks for sharing. | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | thank you sir, having a lot of fun with this
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | ROCKER PANEL IS IN, I HAVE PIC BUT PHOTOBUCKETS NOT PLAYING WELL WITH OTHERS, ON TO MORE STUFF
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup pikup ben busy guna get very busy soon(summer)anyway. epoxy primed some small parts, also cleaning some welds on rockers
1961 apache
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | pikup pikup ok- after priming the smaller pcs. the back side is good but rusty. I got the loose stuff off degreased, andsprayed rustolem rust inhib... no one is guna see it, same as bck side of cowels, ect..
1961 apache
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Chaz, you keep pecking at the pickup and you'll soon be on the road. Thanks for letting us all follow along with you on this journey....one that reminds me of my own journeys over the years as well as currently. Keep up the good work.. | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | thank you achipmunk!!! I hope it comes out as sweet as your rides!!!! you do some outstanding work sir.
1961 apache
