4 members (Samantha, Hanks custodian, Hotrod Lincoln, Otto Skorzeny), 138 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
Page 2 of 2 1 2
Grigg and Paul, thanks. I wasn't sure what a cab and chassis version was. Now I know. That's what I need to look for.
Thanks for the advice,
Matt
Excellent reference Pablo. Thanks for posting.
Do you guys think 3.73 gears would be going to far with an SM420 and a 235? Only casual driving, no work in her future. I assume I can find those for the 14 bolt.
Allen
1974 Stingray Corvette
If your in the flat part of Texas I think they're a good first choice and given you don't expect to haul a lot.
Around here in the mountains 4:10 is a good choice with the original or similar engine. Sometimes on the highway unloaded a little faster gear would work.
•1952 Chevrolet 3800 pickup
---All pictures---
I' m willing to guess that 90 percent of the dually or C&C were 4.10 ratios. 3.73 seems more common in the Single wheel trucks. There is also a 3.42 ratio that seems to be more common in the late model trucks. There is also a 3.21 gear set out there, but you'll only find it used.
Be aware of the 4.56 rearends though, the internals are an entirely different animal.
You can use dually hubs on the 67" axles to make them 63". You can also use the Easton hubs with different bearings to make a 64.5" axle. Either way, you have to get creative with the brakes. Luckily, the van rearends have drums that are more shallow.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
In my experience most of the C&C axles are 4.56. It took me a lot of searching locally to find one with 3.73 gears
https://goo.gl/photos/wkw45S4g9sDPmQwX7
I did find one or two suburban or pickup truck axles with 3.73. suppose that would have worked with hub swap and some fabrication or aftermarket parts for brakes as noted.
---All pictures---
Crusing in the Passing Lane
I agree that the 3.73 gears would be a good first choice.
Ed
Thanks Fellas. As I told Matt in a PM, I still need to check the status of the drums on my 48 (the 52 donor drums are toast) to see if I'll have to move to the 14 bolt, but if I do, I'll have my RE guy find one with a 3.73.
Allen
Don't forget, GM ff 14 bolt axles are typically $150. in most places, if you are willing to do a little searching.
Ed
bluechev #1217305 05/15/2017 12:11 AM
Any Info on Gears would be Very Cool , as 40Mph - 50Mph
Isn't getting it done ..
I Mean it's Cool for Cruising slowly around and stuff
I hauled 2800 lbs the other Day .
Pushing the Temp's up 220 in 1 spot on a long Hill ..
Since then I Installed - Roller Tips & Alu. Valve Covers
with Better Breathers . Running Cooler ..
Also New Wires & Plugs - seemed to - Cool Motor - I don't have to Push on throttle so much ..New Wires were 4 time better then Old ones and Denso Plugs 3 Times Better then Old Plugs
ps: I have seems New Drums Brakes $168.00 Pc.
Expensive but those Things Huge - Last a Life Time !
Your life is made up of Two Dates and a Dash........make the most of the Dash.
http://www.fossilcars.com/chevrolet/1-ton-pickup/869217
1 Offline
Ton of fun, I like alot of others here replaced my pumkin with one from a 70 chevy, 4:10 ratio. Does wonders, I an able to keep up with traffic with no problems.
Yes I do still haul with it and it still has plenty of power with those gears. It's a easy swap, did mine alone in about 6 hours, played withe the grandkids some during that time too. The hardest part is finding a doner.
Have you looked at this? http://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/
Sixteen years ago I paid Randy's Ring&Pinion (on Hwy.99 up your way) to do exactly this procedure. They mentioned in 2001 "good" donors were getting scarce.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
Ok so if I tell my RE guy to search for a center section from a
" 1968-1972 3/4-ton GM truck with the automatic transmission" he's going to charge me for it regardless if it fits or not. It sounds like a pretty sure thing. I just don't have the time right now to go hunting.
Allen
24601
Allen (et al) .... You're thinking too hard!
Just read this thread
Bottom line is that one of our own 'Bolters will set up the swap for you with a dirt track guy looking for our third members and send you back one with the 4.11 gearing. Many of us have done it and it's really a sweet/easy deal where everyone wins.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Yes indeed we are John - Thanks for heads up. I replied to Larry's post as well and will gladly do the swap ASAP if he will just PM me on the particulars. If we can get it done, that's what I call a win win!
Allen
H Online: Content
One of the reasons those ratios are so scarce is that a bunch of us 1/4 mile dirt trackers scavenged up every 4.11 we could find back in the late 1970's. We would run a 4.56 on some tracks, and the 4.11 on slightly longer ones, both running against a 1.88 ratio 2nd. gear in a Muncie 4 speed. The difference was the way the "1/4 mile" was measured. On the tracks that were measured around the outside wall, we needed the 4.56, but if the distance was measured around the infield the 4.11 kept the engine from running out of breath down the straightaway. The idea was to leave the turns at about 3,000-3,200 RPM, and hit 7K before chopping the throttle to make the next turn.
I have 5:14's for Swap - seems there are a lot of Hill Climbers use this Gear .. Off Road etc.
I just cruise the back roads would like to cruise 55 more
Comfortable . .
Also what's Up with the 19.5 inch Wheels - Hub Bore 4.625 , 8 Lug - I have seen a few 2 Ton Vehicles with them and only 1 or 2 two 3800's which to be Split Rims .
Dually set up 3800 1 Ton ..
Offline
Offline
My 56 GMC 250 is a 1.5 ton dually with 19.5's, but not a lock ring rim. I acquired another set from a scrap truck so I'll be able to mount up a set of snow diggies for the winter. I found an old Dodge step van locally with 19.5 singles. I'm yearning to put them on my 69 GMC 3/4 ton 4x4
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Larger Tires are More Expensive , Rims & Tire are very Heavy for the Suspension to Control ..
OK I read up on this and
( It looks like Axles are Larger on H072
1 Ton Eaton vs the H052
So concerned with the Spines on 1 Ton Axle Fitting the Into the Third Member or Carrier assembly .. ?
Thanks so Much Guys - I having some Issues navigating this Forum
Got lost on Responses - sorry .
Again Thanks Much - I have written a few Suppliers , but they either don't get back or don't answer question in Complete Sentences , as Condition of Item for Sale ..
Lets See ( Imagine I have been selling Truck Parts for 20 yrs. ) most these Yards selling for 50 yrs. Haa - They don't have the Foggiest Idea , Yeah Right !
So it's starting to look like I'll have to Go and Pull the Parts
Inspect the Parts and Leave all the Left Overs in the Yard ..
Last Time I got Parts from a Yard 24 yrs. ago - Guy Cut it with a Torch - Hacked Crap out of it . ( He wanted a Tip ) also . LOL
Or they wish to sell You the Entire Worn Out Drums and all Axle ans All - their just to Dam Lazy to put the Pumpkin on the Counter . . ( Who needs the Extra 120 Lbs ) My Drum are A-OK
and Bearing Also . .
#1220164 06/05/2017 11:38 PM
I see what Looks to be same 19.5 Wheels and Offset etc. , but are only 5 Lug ?[i][/i]
Page 2 of 2 1 2
Moderated by  Dusty53
