| | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Is there a difference between the 235 and a283/327 bellhousing? and how would you tell? I am thinking of putting a v8 in my 59 and found a bellhouseing at one of the shops but don't know if its correct. Can I look for a casting /pn on it? | | | | | Joined: Feb 2013 Posts: 111 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 111 | I think I can answer this one, although not in detail. Yes, there is a difference in the block to bellhousing bolt pattern between the 235 and the 283/327. The series of inline 6's after 1962 did share the same bellhousing bolt pattern as the V8's, as I understand it.
Others with more knowledge will certainly chime in. I just caught this one as I am about to announce a mea culpa. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Here is a tech tip that will explain the bellhousings http://www.stovebolt.com/techtips/engines/bellhousings.htmlJust remember, use the starter that fits the bellhousing you use. If you are going to use factory engine front mounts, you'll need the crossmember V8 extension brackets and a set of V8 engine block mounts. Also, the throttle linkage is different for a V8.
1959 3100 Apache Fleetside
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | A huge difference! Two completely different animals. That swap in the '59 should be pretty easy one. Just need to find the bits and pieces from a donor truck or also aftermarket motor-trans mounts are surely out there. Best of luck
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Thanks for the link .That pretty much tells me all I need . Will take those # to the shop and see what bellhousing it is. didnot realise that they used it till 68. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | A quick way to tell car from truck bellhousings is by the side motor mounts...cars have (2) threaded bolt holes on each side, thucks only have one large bolt hole. Mike B  | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | If you're using the stock 3/4 speed that came in the truck, you'll need a bellhosuing with the 4 9/16 opening. A 3815891 bell has that size opening.
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | SCORE !! Went by the shop today and the bellhousing is a 3733365 But best was the guy says its scrap so take it home for free. Will check the dia of the opening as I would like to keep my old 4 speed. Looks like the opening is 4 5/8 hope that is gona work. Well looking at this further it is probably a car bellhousing, there are 2 bolt holes holding the motor mounts and my truck has one. maybe this was not as good of a score.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If memory serves me the car bellhousing has a smaller transmission hole than the truck one. Mike B  | | |
