7 members (3800GUY, Southerntruck, klhansen, dt235sd, Otto Skorzeny, Hotrod Lincoln, farmallb), 71 guests, and 4 robots.
Topics128,079
Posts1,056,301
Members48,441
#1204047 02/12/2017 10:28 PM
Is there a difference between the 235 and a283/327 bellhousing? and how would you tell? I am thinking of putting a v8 in my 59 and found a bellhouseing at one of the shops but don't know if its correct. Can I look for a casting /pn on it?
I think I can answer this one, although not in detail. Yes, there is a difference in the block to bellhousing bolt pattern between the 235 and the 283/327. The series of inline 6's after 1962 did share the same bellhousing bolt pattern as the V8's, as I understand it.
Others with more knowledge will certainly chime in. I just caught this one as I am about to announce a mea culpa.
1942 Chevrolet 1 1/2-ton (G-506 Military) Panel
Short video
Longer video
Here is a tech tip that will explain the bellhousings
http://www.stovebolt.com/techtips/engines/bellhousings.html
Just remember, use the starter that fits the bellhousing you use. If you are going to use factory engine front mounts, you'll need the crossmember V8 extension brackets and a set of V8 engine block mounts. Also, the throttle linkage is different for a V8.
1959 3100 Apache Fleetside
A huge difference! Two completely different animals.
That swap in the '59 should be pretty easy one. Just need to find the bits and pieces from a donor truck or also aftermarket motor-trans mounts are surely out there.
Best of luck
1946 1/2-Ton Chevy
Thanks for the link .That pretty much tells me all I need . Will take those # to the shop and see what bellhousing it is. didnot realise that they used it till 68.
A quick way to tell car from truck bellhousings is by the side motor mounts...cars have (2) threaded bolt holes on each side, thucks only have one large bolt hole.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
If you're using the stock 3/4 speed that came in the truck, you'll need a bellhosuing with the 4 9/16 opening. A 3815891 bell has that size opening.
SCORE !! Went by the shop today and the bellhousing is a 3733365
But best was the guy says its scrap so take it home for free. Will check the dia of the opening as I would like to keep my old 4 speed. Looks like the opening is 4 5/8 hope that is gona work. Well looking at this further it is probably a car bellhousing, there are 2 bolt holes holding the motor mounts and my truck has one. maybe this was not as good of a score.
If memory serves me the car bellhousing has a smaller transmission hole than the truck one.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
