1 members (Hush),
73
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Ok I officially feel dumb , but I don't want to continue without some advise. I'm going though my 58 Viking 60 grain truck trying to get brakes. The front check when fine. Bearings good wheel cylinders try plenty of brake pad. Go to sismont dully wheels...( never owned a dually). Took off lug nuts 6 of them on this axle, ant thought the inner wheel would just come off easy as I thought lugs held both bud type wheels onto hub. But nooooo. Stuck on. The ends of wheel studs on rear have a square end on them. Do I have to take off the studs or is the wheel just wedged un tight. I tried using a lever against frame to tire with no luck. These wheels were just installed on truck. 21.5 s 8 inch a couple months ago. Help or suggestions please ,,,, no laughing lol | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | They are stuck. Happens all the time. Just have to get aggressive with a bar and BFH.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No! Step away from the BFH. Budd wheels (which I'd expect on that model) use inner and outer nuts. Usually 1.5" socket for the outer lug nuts and 13/16" square for the inner lug nuts.
If you've removed some wheels you've probably figured out they are left hand thread on the left side of the vehicle. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 |
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Yep, if the square shank of the inner nut has an "L" stamped on it, it turns clockwise to loosen. LOTS of torque, at least 150-200 FT/LBS will be required.
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks guys. Now let me point out that I The wheel studs in rear on duals do have a square end on the stud. Am I understanding that this whole stud turns out to get inside dual off. I looked at stud end at the inner wheel opening at it is cone shaped with the six lug holes centered on each stud at brake drum There is no second lug nut btwn the two bud style wheels. What am I missing? Thanks for all the input. Also. I read in the shop manual that the back drums are bolted on????? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Have a look at this Budd lugnut and stud diagram http://www.autoamenity.com/images/Stud-Pilot-System.jpgThe "second lug" is the stud looking part with square end on it. To remove dual wheels with this mounting system first remove the big nut looking lug nuts, then outer wheel falls off. Lastly remove the stud looking inner lug nuts with square heads, and inner wheel falls off. | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks Grig Now to fined a square impact socket. Lol. This is quite an adventure Hoping the tire shop guy on service truck didn't torque them down to the point he did the outer nuts. Btwn I've had a heck of a time finding bleeder valves that are the same thread to end of seat distance. Ordered from three places. None seat out properly. Wondering if over tightening them have ruined my rear brake wheel cylinders | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If the bleeders are stuck in, GENTLE heat will frequently ease their removal.
Ed
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Oh I got them out but are ant ing to replace then with a nipple style replacement so I can back bleed or vacuum bleed brakes. The originals have a bleed screw in end of bleeder The ones I keep getting from suppliers have different distance from end of Thea's to bleeder hole and the seat thus not stoping fluid flow even when tightened down | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | txpete, you gotta stop using auto-correct! What's an "ant ing" and a "Thea's"? Proof read before you hit submit please, some may be able to figure out what you are asking but us challenged folks are having a hard time keeping up.
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Thanks Grig Now to fined a square impact socket. This socket combines the 1 1/2" outer nut and the square hole for the inner nut in one tool. I use one frequently. https://www.amazon.com/Sunex-4121C-Drive-Combination-Socket/dp/B000ROFZ6SJerry
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks Grigg ordered today. Will my rear drum have bolts holding it on? Can't see anything in the shop manual to say. Not sure if I have a Eaton rear end or not ( way to new to big bolting) my Vin is 6C which I understand from gm historical datA site suggested hear on this forum, means I have a 6500. It's a 174 inch wheelbase. Standard cab. Either a 283 or a 283 super taskmaster. Paint on engine under Grease is Aqua color. The Rearend is vacuum two speed tranny sm420 I tried to back off/loosen upper rear shoes today before vacuum bleeding system in the order shop manual lays out,,,,,burn the adjustment wheel was frozen so I couldn't compress that wheel cylinder as instructed in shop manual,,,,thus some air left in the system. The brakes would pump up when I was done but softened when sitting an hr or two but pump back up. Drove it on our back road and could lock up back left when hydrovac kicked in but was only two inchs off floorboard. I know I got to get in rear hubs to clean and get adjustment working and investigate ahape of components so the tool should get me there next weekend. Thank you | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Your vacuum shift rear will be a Corporate GM rear, not an Eaton. Make sure ALL of your brake shoes are adjusted with heavy drag when turned the tire by hand, if not you will have a low pedal. Mike B  | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | txpete, you gotta stop using auto-correct! What's an "ant ing" and a "Thea's"? Proof read before you hit submit please, some may be able to figure out what you are asking but us challenged folks are having a hard time keeping up.  I took them as "wanting" and "threads", but only he can tell us for sure. | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks Mike. Gosh weeding though the historical data on options on these trucks and trying to glean clues from shop manual can be confusing to us less mechanic ly minded folk. Thank you all for taking tome to help all us new To big bolts | | | | | Joined: Sep 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2015 Posts: 28 | Will the above socket on Amazon work for my 53 GMC 6400? Is it also left hand threads on the left side of the truck?
Thanks!
53 GMC 2 Ton Stake Bed 61 C60 Project/Yard Art 72 Toyota FJ40 292/SM420 36's etc 92 LS400 Track/Drift car project 99 Superduty 7.3 Powerstroke Gooseneck hauler 07 Honda Accord V6 6speed kid hauler
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Have a picture of the wheels and lug nuts? 6400 is not a usual GMC model number for 1953 is it?
You could also measure the size of the nut (and square if any) then confirm whatever socket(s) you buy match. | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Historical data showed 6400 designation for a 174 inch wheelbase cab chassis combo. I believe,,,, but I've been wrong b4. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Will the above socket on Amazon work for my 53 GMC 6400? . . . . . . 6400 is not a usual GMC model number for 1953 is it? Historical data showed 6400 designation for a 174 inch wheelbase cab chassis combo. I believe,,,, but I've been wrong b4. Maybe 6400 model for 174" wheelbase on a Chevrolet Advance-Design truck? The make/model in question is a GMC (probably a 350 series?). Nonetheless, I think a 1953 Chevrolet 64xx would have had a 161" wheelbase, with 179" being the wheelbase for a 6500?? | | | | | Joined: Sep 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2015 Posts: 28 | Well now I feel stupid.. Here is my truck, pretty sure its a 2 Ton (16k GVW) I thought the chassis designation would be the same as the Chevy? http://i1149.photobucket.com/albums...eb4y.jpg?1487101938008&1487101939154
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You don't need a special socket just whatever you already have that fits, or off the shelf that fits. Judging by what I can see on the front axle/wheels you have 10 lug on 7.25" bolt circle hub centered wheels, not stud centered Budd wheels. I don't expect you have any left hand threads either. If I'm wrong or confused please share more detailed pictures.
Socket might be anything between 15/16 and 1-1/8" depending on what nuts were used, I don't recall off hand the factory hex size on the standard 5/8" fine thread lug nuts.
Grigg | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | On the right side of the right front framerail, might be stamped in large letters and numbers and MN.
Ed
| | | | | Joined: Feb 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Feb 2017 Posts: 93 | I was cleaning the rats nests out of my new 58 Viking yesterday, and found what I think is the original lug wrench. It is about 1.5 to 2 feet long. One end has the square nut, the other the 1.5 socket. There is a hole on the shaft on either end that I assume had a removable steel rod. That is missing so far, but I will walk the junkyard looking for a replacement at lunch.
ps, this thread saved me a lot of headache and potential breaking of parts. Thanks all
1959 Chevy Viking. Belonged to my Great Grandfather
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Or just get a piece of cold rolled steel of the correct dia.
Ed
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | | | | | | Joined: Feb 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Feb 2017 Posts: 93 | turns out mine is a 59 not a 58. I have not found the frame vin number yet, but the door panel matches the title, so I think it is all the same original truck. Found a heavy duty lug wrench star in my cousins shop last night. Two of the ends have deep square nuts behind the normal socket head. Have not tried yet, but I am guessing that one will fit the inner lugs on my truck.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | "If you've removed some wheels you've probably figured out they are left hand thread on the left side of the vehicle." To be more correct,they SHOULD be Left side=Left hand threads...When I did the brakes on my '51 Fowerd F-5,I discovered whoever did the brakes previously got it all wrong.It was something of a battle finally getting everything apart,getting the brakes done and getting it all back together in the right locations. I was told early on,"Ya can't get it wrong-all the studs and nuts are marked R or L.",but they WEREN'T! (WTH?) Speed | | |
