1 members (NorthCoast3800), 54 guests, and 3 robots.
Topics128,153
Posts1,056,849
Members48,456
Although I think I've seen this discussed before I searched and found no answer. I am working on my '47 3100 front-end and need to replace the ball studs on the drag link and tie rods. It is my intention to run 6 lug 4x4 Rally wheels when I finish the truck. Should I upgrade the tie rod ends and drag link with the more modern style or replace with the stock style. I'm installing a 235, T5 and later model rear axle. I intend on driving at highways speeds.
Do you care if they look modern or look original?
You can find original-style replacements (adjustable) or modern, "sealed" replacements (non-adjustable).
New (original style) tie-rod ends and a properly adjusted steering assembly allow me to cruise smoothly and straightly at 60-65 mph (3.55 R&P conversion).
Originality isn't of too much importance due to the many other modifications.
The offset on the rally wheels may make some difference of clearance on the tie rod end.
On my 52 Panel, which still has the straight axle/suspension I changed to the modern stuff and I'm using a 10" wide wheel.
I have read where some bolters had a problem with the tires rubbing the original tie rod end. So be sure to check when buying rims or tires.
I have the modern tie rod ends on my 59. I have the rally style 6 lug wheels and don't have a problem with tires rubbing. 7 inch in front, 8 in back. The rally wheels are the kind that came on early Monte Carlos,and corvettes.
Tommy
59 apache 1/2t
261 short stepside
I'm still running the stock style tie rod ends on my '55 2nd with 15 x 8 4x4 Rallys, they have plenty of clearance.
Bill Burmeister
Tommy if your rally's are the style off early corvette or Monte Carlo they can't be six lug, as they were only five lug. Possibly off an early blazer? For six lug?
Joe
Probably was of a blazer, just used monte carlo/vette as an example that people commonly see.
Tommy
59 apache 1/2t
261 short stepside
There are actually 6 completely different styles of Chevrolet Rally wheels, 5 are 5 lug, 1 is 6 lug. The styling is different on all 4.
Corvette/Passenger
Rally 2
S 10 2wd/
Nova/Camaro Rally
5 lug Truck/Van Rally This wheel can also be found on some full size Chevrolet cars, usually in white.
6 lug Rally, commonly known as the Blazer Rally
Bill Burmeister
