4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#119871 03/13/2006 2:40 PM
Anyone ever use this:
http://www.eurekafluidfilm.com/
Larry Bear
55.5 Chevy 3100 Panel
#119872 03/13/2006 4:09 PM
never have but I really can't figure out where I would use it except on the battery box and cables.
#119873 03/14/2006 2:45 AM
They say you can use it all over, especially underneath - wheelwells, etc.
A guy stopped in the store last Sunday and swears by it.
Larry Bear
#119874 03/14/2006 3:47 AM
That is what I use where others use WD40 and it is really amazing. I am part way through restoring a very rusty truck and I have undone some pretty unlikely candidates using Fluid Film. I also used it to free up my stuck 216 that sat out in the weather for over 15 years.
1951 1 Ton Completed
#119875 03/14/2006 7:09 PM
Do you plan to put a layer of application underneath for protection? That's what I understood it was for... to prevent rust after refinishing.... sounds like you're using it to free up stuck stuff, yes?
Larry Bear
#119876 03/16/2006 8:44 PM
Larry,
I buy mine in a spray can and I use it like penetrating oil, on threads that stick after acid cleaning and sometomes for the cutting edges of a drill bit or tap.
