1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | never have but I really can't figure out where I would use it except on the battery box and cables. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | They say you can use it all over, especially underneath - wheelwells, etc.
A guy stopped in the store last Sunday and swears by it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is what I use where others use WD40 and it is really amazing. I am part way through restoring a very rusty truck and I have undone some pretty unlikely candidates using Fluid Film. I also used it to free up my stuck 216 that sat out in the weather for over 15 years. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Do you plan to put a layer of application underneath for protection? That's what I understood it was for... to prevent rust after refinishing.... sounds like you're using it to free up stuck stuff, yes? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Larry, I buy mine in a spray can and I use it like penetrating oil, on threads that stick after acid cleaning and sometomes for the cutting edges of a drill bit or tap. | | |
