4 members (ShopRag, Phak1, Gdads51, Hotrod Lincoln), 88 guests, and 7 robots.
Topics128,181
Posts1,057,152
Members48,464
I am looking at upgrading the stock master cylinder with a newer style master cylinder and 7" booster. I also want to add a clutch master cylinder so I can use a hydraulic slave cylinder. I have seen several "universal" type setups (like the one in the link below)
but I am worried about the pedal alignment.
https://www.fabquest.com/tci-universal-manual-combo-brake-and-clutch-pedal-assembly.html
Has anyone us used one of these? I have seen a lot of the single brake pedal adapters that use the stock pedal with the automatic trans but not any that use both the stock pedals.
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Ok option #2, Maybe someone know what a good donor vehicle would be for a clutch and brake pedal assembly that would fit under the dash on an AD truck?
I picked up a Jeep pedal assembly a couple years ago. I haven't mounted it yet, but it seems like a good fit. I also bought a Toyota clutch master, because of it's hose mounting configuration and it was dirt cheap.
1954 3600 Chevy Truck
"The Fake Truck"
Whitedog do you remember what year of Jeep?
I think a firewall mount and hanging pedals will be a must. After looking at the area the original pedals will occupy I don't think I will have the travel space required to operate the brake pedal without hitting the exhaust manifold, Nor is there much room under the cab for a Master cylinder, booster and clutch reservoir combo with the new transmission crossmember installed.
http://i1062.photobucket.com/albums...7-49AE-B935-CF44981D16ED_zpsun0hff6f.jpg
http://i1062.photobucket.com/albums...2-46EA-B15F-5485D87E103D_zpsatwjtr9v.jpg
Crusing in the Passing Lane
I mounted hydroboost and Wilwood clutch master on reinforced firewall of my '37 GMC, plenty of room; found some old Jeep clutch and brake pedals(cast iron), turned them upside down, work great with firewall masters.
Ed
The pedals were from a Jeep TJ (97-06).
I didn't like the looks of any of the aftermarket pedals. Not to mention the price.
I wanted something with more of a factory look.
Here's a picture of them compared to the OE placement.
http://s1074.photobucket.com/user/w...amp;_suid=147883898132707876844700499707
I know I'll have to tackle some firewall reinforcing and master cylinder placement, but it should be a fairly clean setup when it's all done.
"The Fake Truck"
s10 or s15 might work.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Thanks Whitedog keep us updated with the installation process.
Blind i have a 49 suburban and I got a hanging pedal from early 70 nova with booster etc. I did reinforce the firewall to reduce any flex.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Looks like a setup for a 4 legged driver.
Ed
Awesome, Do you have any pictures of the installation or the finished product?
Moderated by  Dusty53
