5 members (dt235sd, Hush, Rich'sToys, Toadwart, 1 invisible), 296 guests, and 3 robots.
Topics128,087
Posts1,055,999
Members48,430
Junior Member
Junior Member
I've got old, oxidized paint. What's the best, temporary thing I can do to it to polish it up and make it look somewhat presentable? Products? Methods? Thanks!
Try getting some extra fine rubbing compound from the auto parts store. Practice in a hidden or less noticeable area. Follow the instructions and follow up with a nice rich wax. Good luck!
~ Kimberly
My '54 ... and my '63 and a '59 F100
rub it down with Diesel fuel. I once did a 54 that way and it made the old dead paint look brand new. I really did this and it helped, for a time, but it sure did collect red dust a lot grin
If it's OLD, OLD as you say, you will be down to the metal before it shines. The elements do a number on the OLD paint. How OLD is it?
I wouldn't use diesel fuel, comet, or anything other than wax and rubbing compound, or just let it be. The reason being that the oil and silicones in those products will give you fits when trying to repaint the metal. The best protection to the metal would be a good coat of wax. Know that if you rub the oxidation off the paint will get thinner. I suggest you leave it alone until you paint it. If you need it to look good for a photo just wash it and take the pictures while it is wet.
Paint & Body Shop moderator
Z
Z Offline
ive thought of tring to wetsand mine with ultra fine sandpaper.
wet sand with 1200 then compound then wax
Bon Ami, is a cleaning powder I used on my 56. It will not scratch and leaves the paint shinny and clean, ready for some good wax.
Just a side note, when ever I cleaned my 56 with Bon Ami people would ask me if I got my truck repainted.
how did you apply the bon ami????
With a soft cloth.
wet sand it then clear coat it clear coat on ebay is cheap
