4 members (Hotrod Lincoln, Steelonsteel, JeffA, dt235sd), 145 guests, and 5 robots.
Topics128,246
Posts1,057,885
Members48,477
Page 1 of 2 1 2
#1194664 12/10/2016 4:33 PM
1961 apache. front end is off. I saw 58 chrome headliet bezels for sale. will they bolt to my 61 grill. they look? the same.
1961 apache
chaz71 #1194843 12/11/2016 3:48 PM
last nite took seat out, disconnect small things from cab. some floor rot to address. next step cab off frame
1961 apache
chaz71 #1194871 12/11/2016 8:01 PM
Don't think the bezels are the same.
Tommy
59 apache 1/2t
261 short stepside
chaz71 #1194970 12/12/2016 3:37 PM
im guna get a beatup bezel off e bay, bolt holes look darn close lol
1961 apache
chaz71 #1194971 12/12/2016 3:37 PM
1961 apache
chaz71 #1195168 12/13/2016 4:49 PM
PM sent. I think I know of one. Thanks JP
chaz71 #1195890 12/18/2016 5:18 PM
last nite I got all the cab bolts off. got lucky! next is steering colom. im guna try to take the cab off the frame, that's the plan, lol. more to cont......
1961 apache
chaz71 #1196286 12/21/2016 11:24 AM
00P0P_ho0ebnK11nf_600x450[1
1961 apache
chaz71 #1197215 12/28/2016 10:52 AM
got the steering wheel/Colum out this week end
1961 apache
chaz71 #1198063 01/03/2017 12:39 PM
removed fuel tank( great shape) got the cab on 2x4's. cant move it yet, motor in the way. starting to remove the bed.
1961 apache
chaz71 #1199076 01/09/2017 9:07 PM
removing paint on the part of the grill in front of the rad. sprayed bed bolts. found some ideas for brake/clutch issue. ccp has a nice combo with booster and pedels!
1961 apache
chaz71 #1199655 01/14/2017 2:49 PM
this is wat she looked like wen I got her pikup
1961 apache
chaz71 #1199933 01/16/2017 12:44 PM
this is how she sits now. not much dun this weekend pikup
1961 apache
chaz71 #1200226 01/18/2017 12:35 PM
don't know if im in the rite spot, doing this rite? anyway more progress pikup
1961 apache
chaz71 #1200239 01/18/2017 3:25 PM
Chaz, you just keep adding to a post about grills. The best thing to do if your intention is to document your progress/build is to start a thread in the Project Journal Forum or the DIYT Sub-Forum in the welcome center. This will get you more exposure. If you have a specific question about a certain item or task then post that question in the appropriate forum for that item or task. Hope this helps.
chaz71 #1200391 01/19/2017 10:58 AM
thank you sir
1961 apache
chaz71 #1200840 01/22/2017 1:50 PM
got the bed pulled back, removing cab will be nxt pikup
1961 apache
chaz71 #1202053 01/29/2017 4:41 PM
REMOVED CAB LAST NITE pikup
1961 apache
chaz71 #1202691 02/02/2017 11:45 PM
a little start on some small pieces pikup
1961 apache
chaz71 #1203089 02/05/2017 11:24 PM
finial got things moved around, also some new parts pikup pikup
1961 apache
chaz71 #1203973 02/12/2017 2:40 PM
workin on pass side, rocker removed pikup pikup
1961 apache
chaz71 #1204958 02/19/2017 1:40 PM
this is the only bad floor brace, starting to remove pikup
1961 apache
chaz71 #1205934 02/26/2017 2:56 PM
well not so much workin on the apache this weekend, granddaughter b day party then onto getting new glasses. then back to work. dosent time fly !!!
1961 apache
chaz71 #1206491 03/01/2017 10:17 PM
pikup pikup had the day off. front brace is shot. removed it. some of the floor is bad 2nd pic, started removing it
1961 apache
chaz71 #1206793 03/03/2017 9:17 PM
pikup pikup fitting new panels in
1961 apache
chaz71 #1208910 03/16/2017 9:53 PM
big snow storm! new phone( pain in the neck trying to figure out) anyway... GOT THE NEW INNER ROCKER/FLOOR in.trying to keep as much old floor as possible, most of it is good. also installed fron floor brace. pics will come as soon as photobuket behaves. lol
1961 apache
chaz71 #1209125 03/18/2017 1:19 PM
1961 apache
chaz71 #1209242 03/19/2017 3:06 AM
And here I was hoping we were talking about grilling a couple flank steaks with cherry wood, etc.
Craig
chaz71 #1209465 03/20/2017 11:16 AM
lol these are harder to chew. but! I did score a complete grill inner/ outer headlite bezels, hood eyebrow inserts, all in chrome!!! will show pics wen ups delivers.
1961 apache
chaz71 #1209540 03/20/2017 9:24 PM
Man, some guys have all the luck! Congrats.
chaz71 #1209543 03/20/2017 9:52 PM
pikup you can see in the older pics the bottom was shot. getting closer to the rocker panel inst....
1961 apache
chaz71 #1209804 03/22/2017 11:57 AM
pikup what a score! my front end is dun.whole pacage on ebay.
1961 apache
chaz71 #1209881 03/22/2017 10:20 PM
pikup pikup mocking up the rocker panel
1961 apache
chaz71 #1209892 03/22/2017 11:47 PM
Slowly but surely. Nice job. Thanks for sharing.
chaz71 #1209973 03/23/2017 10:53 AM
thank you sir, having a lot of fun with this
1961 apache
chaz71 #1210350 03/26/2017 3:25 PM
ROCKER PANEL IS IN, I HAVE PIC BUT PHOTOBUCKETS NOT PLAYING WELL WITH OTHERS, ON TO MORE STUFF
1961 apache
chaz71 #1211293 04/02/2017 1:30 PM
pikup pikup ben busy guna get very busy soon(summer)anyway. epoxy primed some small parts, also cleaning some welds on rockers
1961 apache
chaz71 #1212093 04/07/2017 11:07 PM
pikup pikup ok- after priming the smaller pcs. the back side is good but rusty. I got the loose stuff off degreased, andsprayed rustolem rust inhib... no one is guna see it, same as bck side of cowels, ect..
1961 apache
chaz71 #1212738 04/12/2017 2:01 AM
Chaz, you keep pecking at the pickup and you'll soon be on the road. Thanks for letting us all follow along with you on this journey....one that reminds me of my own journeys over the years as well as currently. Keep up the good work..
chaz71 #1212781 04/12/2017 10:24 AM
thank you achipmunk!!! I hope it comes out as sweet as your rides!!!! you do some outstanding work sir.
1961 apache
Page 1 of 2 1 2
