| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | My 56 needs the entire block to make a u-turn. Is there a fix for that? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What size truck? Original or aftermarket wheels and or anything else steering related? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1956 3600?
145" radius (24' diameter) in a 3600 vs 115" radius in a 3100" (19' diameter)
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I have a 1956 Chevy 3600 with 16" rims. 256/75/16 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My 56 needs the entire block to make a u-turn. . . . A "typical" city block is 264' to 352' long. | | | | | Joined: Nov 2010 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 122 | Is it the same turning left and right? | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | All stock? (Turning radius is what is, in my opinion not bad) Non stock; what parts? (Could cause reduced radius?) | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Its all stock. I have owned a 47 and a 53 that turned much better. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I bet these old trucks could turn inside my 2006 Toyota Tundra. First thing I noticed after I bought it. Brutal turning radius in that truck. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Did your other trucks have same wheelbase, were they also 3/4 tons? The longer the truck the longer the turning radius given same front axle and steering stuff.
When you turn it hard one way or the other what limits the wheel cut? Are the spindle stops on the axle there as original or installed wrong, adjusted wrong if adjustable? On my 1 tons I always thought they turned quite nice. Even with larger tires that at max turn just wanted to rub the back of the front springs. If your tires are close to rubbing the springs as max turn that's best you can do. Assuming original type and size wheels and not aftermarket ones extra wide or with to much inset. | | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | I have a 1956 Chevy 3600 with 16" rims. 256/75/16 I'm assuming that tire is a 265 width, WAY wider than stock and you are rubbing the frame. Reduce width of tire, reduce turning radius.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Many steering geometry's' are set up to turn slightly tighter to the right. My '46 was that way. I measured it. An old timer/rod builder buddy told me it was to accommodate the fact that making a right hand turn at a corner called for a few more degrees to clear the other lane. When I replaced the steering with an Isuzu hydro set up, I set it up as close as possible to what the original had been...which was just a bit tighter to the right.
"Right" or not, it seems to work well. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tango, I think your on to something. Not trying to be cute here but have ya'll noticed your lawn mower will turn sharper one way than the other. ...I give engineers credit when credit is due, and there are some engineering feats out there that some pretty slick folks figured out and when we "discuss" things we usually have a better understanding of "why". | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think the sharper to the right is plausible but unlikely. If the amount of steering is before tires hit frame, springs, or what not.. then the truck being built symmetrical left and right should turn same either way. No reason to give up turning radius on either side just to say the truck turns more to the other side.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | My Kabota UTV turns much sharper left than right. Go figure!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I built/modified a truck with a different front axle and a big steering box outside the frame in front of the axle. It would turn to the left seemingly with the left rear wheels stationary (but not quite). It'd easily do a U-turn within 3 lanes, a truck with same wheelbase as a modern crew cab with long bed. However to the right the tire hit steering box and turning radius was just adequate, nothing special. A compromise to get that axle and PS in there. | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | The truck came with 17 1/2 rims but the tires were narrow. I'll bet you are right. I'll have to check that out. | | |
