7 members (Wally / Montana, greenie-reddy, sron48, padresag, walter74, Wayne67vert, Shaffer's1950), 92 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
#1193863 12/05/2016 12:24 AM
Anyone have any suggestions or recommendations on the hydraulic fluid brand or type to use when draining and refillingg the hoist on my 58 Viking grain truck? I don't know how old it is and assume I should change it out. The hoist works fine with a small leak at the pump
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Q
Q Offline
Aw68 is a good general purpose use hydraulic oil.can't tell you what brand to get as I don't what's available to you in Texas. It would also be good to change the filter. If you don't have ano external filter then it will be in the tank..Many parts stores will have it,equipment shops or farm supply stores.
3B Offline
Hy txpete, most of my hydraulic systems are so leaky that I just buy a pail of whatever is on sale, you can use almost any engine oil or automatic transmission fluid can also be used, hope that helps.
Moderator
Moderator
2 Offline
Not trying to steal your topic, But I have a question related.
Hydraulic Fluid Question.
What about a 1967 GMC 9500 with a 65' Grove hydraulic ladder?
I did some searching a few years ago, and there is not much info out there on the Hydraulics at all.
Heck, I can't even find a print on the design of the hydraulic system.
AW68 will be the one I use, unless somebody tells me different.
My thoughts are, that if it is not a Fyrquel brand hydro oil, and the right viscosity, it will work just fine.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
A lot of the dump trucks I've worked on over the past 40-something years used plain old 30 weight non detergent motor oil.
The maintenance manual for my 1941 Hercules dump ram calls for a 10 weight oil, AW32 is what I use.
Lots more pictures
I always use automatic transmission fluid. Been doing that for 30 years without issue.
1950 4100 - unrestored and driven weekly for almost no reason at all.
Thank you all for the timely and good info... Keep helping ,,,,we newbies appreciate your knowledge
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Btw my hoist is an Omaha Standard original add on totruck I was was told by 2nd owner (67-2016)
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
I use the same hydraulic oil I use in my tractors, a type 303 for JD and others. I think it's 20W.
Many years of working on hydraulic systems on all kinds of antique farm equipment and lift bodies comes down to the following formula:
Good pump and seals - AW32 hydraulic oil
Slightly worn pump & valves, weeping seals - AW46
Very worn pump & valves, drippy seals - AW68
