| | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | The lower hood latch assembly on my '49 3100 is really worn and weak. Can someone suggest an aftermarket latch that is good quality? Don't really want a black painted one or chrome. Would prefer the zinc plated latch like the one I removed from the truck. Any suggestions or help with this would be much appreciated!
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Jun 2009 Posts: 814 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 814 | Why not put a good, used original back in? You should be able to find one here on "the 'Bolt". If not, turn to eBay. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Tim, is a 52 the same?? if it is PM me. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Alvin,
Thank you for the offer on the lower hood latch. Took my hood latch apart and found a local welder friend who was able to build up the material that had worn on my latch. Planning to clean it up good and reassemble it. If it doesn't work after the rebuild I will definitely take you up on that offer. From what I understand the lower latch assembly was the same for 1947-1953 Chevrolet trucks.
Thanks again!
Tim
