7 members (Bill Hanlon, Guitplayer, LAROKE, Cosmo, JoergK., Wayne67vert, 4tttt8),
108
Mod | | | Forums66 Topics128,180 Posts1,057,167 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | I am looking at upgrading the stock master cylinder with a newer style master cylinder and 7" booster. I also want to add a clutch master cylinder so I can use a hydraulic slave cylinder. I have seen several "universal" type setups (like the one in the link below) but I am worried about the pedal alignment. https://www.fabquest.com/tci-universal-manual-combo-brake-and-clutch-pedal-assembly.htmlHas anyone us used one of these? I have seen a lot of the single brake pedal adapters that use the stock pedal with the automatic trans but not any that use both the stock pedals.
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Ok option #2, Maybe someone know what a good donor vehicle would be for a clutch and brake pedal assembly that would fit under the dash on an AD truck?
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I picked up a Jeep pedal assembly a couple years ago. I haven't mounted it yet, but it seems like a good fit. I also bought a Toyota clutch master, because of it's hose mounting configuration and it was dirt cheap. | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Whitedog do you remember what year of Jeep?
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I mounted hydroboost and Wilwood clutch master on reinforced firewall of my '37 GMC, plenty of room; found some old Jeep clutch and brake pedals(cast iron), turned them upside down, work great with firewall masters.
Ed
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The pedals were from a Jeep TJ (97-06). I didn't like the looks of any of the aftermarket pedals. Not to mention the price. I wanted something with more of a factory look. Here's a picture of them compared to the OE placement. http://s1074.photobucket.com/user/w...amp;_suid=147883898132707876844700499707I know I'll have to tackle some firewall reinforcing and master cylinder placement, but it should be a fairly clean setup when it's all done. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 |
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Thanks Whitedog keep us updated with the installation process.
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Blind i have a 49 suburban and I got a hanging pedal from early 70 nova with booster etc. I did reinforce the firewall to reduce any flex.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Looks like a setup for a 4 legged driver.
Ed
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Awesome, Do you have any pictures of the installation or the finished product? | | |
