Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, UtahYork, 66flea), 163 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#118898 12/26/2005 9:09 PM
Removed a front bumper bolt from my 49 and when I tried to put a new one in it would not go. Seems the bumper/bracket and valance panel were under tension. With a bit of persuasion it will go back but I am putting on bumperettes and cannot get a good grip on the bolt when it goes into the holes. I did consider removing the entire bumper assembly including the brackets and putting it back piece by piece. Any ideas?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#118899 12/26/2005 9:10 PM
Sorry. When I said it would not go in it was because the 3 holes are not lined up.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#118900 12/26/2005 10:07 PM
on my '48, I had a similar problem and loosened all the bolts and that helped them line up.
that's what I have discovered so far.
Jimmy
