| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Removed a front bumper bolt from my 49 and when I tried to put a new one in it would not go. Seems the bumper/bracket and valance panel were under tension. With a bit of persuasion it will go back but I am putting on bumperettes and cannot get a good grip on the bolt when it goes into the holes. I did consider removing the entire bumper assembly including the brackets and putting it back piece by piece. Any ideas? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Sorry. When I said it would not go in it was because the 3 holes are not lined up. | | | | | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | on my '48, I had a similar problem and loosened all the bolts and that helped them line up. that's what I have discovered so far. Jimmy | | |
