2 members (papas52, carbking),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 31 | my 1954 pick up 4speed throw out fork came off bell housing ball. What is involved getting it back on. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is a spring clip in the socket. If it is not broken the arm will pop back in place. If it is broken, replace it. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Make sure that the ball and socket isn't worn out.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Broken fork spring clip is very common. | | | | | Joined: Oct 2015 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 31 | can I pop it back on with a pry bar through the bottom of the bell housing? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I find the little spring breaks when I take it apart. For this reason I always buy more than one.
Normally you should be able to pry it back on but I wonder why it came off. I don't think it should have that much freedom. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I agree that the clip has likely failed. Good idea to make sure the pivot ball isn't badly worn. Also, make sure the clutch pedal linkage is properly adjusted. If the fork arm is contacting the bell when the pedal is in the full down position, then that would have enough leverage to pop the fork off the pivot ball. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Even if the retainer spring is worn out or broken, if the clutch free play is properly adjusted the fork can't move out of position. If the ball is worn out or broken off, it's time to remove the transmission and maybe the bellhousing and replace the pivot ball. Later ones installed from the back of the bellhousing with a big Allen wrench- - -not sure about yours. Jerry
| | | | | Joined: Oct 2015 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 31 | I appreciate the information and help | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | On my 38 Master which has probably the same design, the ball and stud and the arm can be replaced without removing the transmission. | | |
