1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
my 1954 pick up 4speed throw out fork came off bell housing ball. What is involved getting it back on.
There is a spring clip in the socket. If it is not broken the arm will pop back in place. If it is broken, replace it.
Make sure that the ball and socket isn't worn out.
Broken fork spring clip is very common.
can I pop it back on with a pry bar through the bottom of the bell housing?
I find the little spring breaks when I take it apart. For this reason I always buy more than one.
Normally you should be able to pry it back on but I wonder why it came off. I don't think it should have that much freedom.
1951 1 Ton Completed
I agree that the clip has likely failed. Good idea to make sure the pivot ball isn't badly worn. Also, make sure the clutch pedal linkage is properly adjusted. If the fork arm is contacting the bell when the pedal is in the full down position, then that would have enough leverage to pop the fork off the pivot ball.
Even if the retainer spring is worn out or broken, if the clutch free play is properly adjusted the fork can't move out of position. If the ball is worn out or broken off, it's time to remove the transmission and maybe the bellhousing and replace the pivot ball. Later ones installed from the back of the bellhousing with a big Allen wrench- - -not sure about yours.
I appreciate the information and help
On my 38 Master which has probably the same design, the ball and stud and the arm can be replaced without removing the transmission.
