6 members (Wickedbass, jkreiner, mvigo, Charles in CA, Rusted Nut, 1 invisible), 75 guests, and 3 robots.
Topics128,074
Posts1,055,913
Members48,429
#1187861 10/23/2016 1:16 AM
Did a 1946 2 ton have a glove box light option?
Was there a glove box light for the lighter 1946 Chevy trucks? Is it safe to assume if there was such an option they would fit in the 2 ton?
Thanks. Jeffrey
32vld #1187898 10/23/2016 5:02 AM
We had a '46 1 ton pickup when I was growing up. There was no light in the glove box.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
32vld #1187938 10/23/2016 2:41 PM
Crusing in the Passing Lane
Keep us informed, nice addition to any truck.
Ed
32vld #1188109 10/24/2016 11:15 PM
Unless I missed finding it, the Accessory Catalog doesn't show one. There is a coutesy light and switch below the dash center.
32vld #1188112 10/25/2016 12:03 AM
I'll look for that light and switch. Thanks
Jeffrey
32vld #1188130 10/25/2016 2:47 AM
2 Offline
That switch on mine is actually a 3 position. The three positions on mine are right-light through the opening in the dash above the key/throttle/choke, center-off, and left-dash illumination when the headlights/parklights are on. The switch is located on the bottom edge of the dash, left of the ashtray, and the switch is a slide that moves through the three positions in a right-left direction facing the dash. Needless to say mine generally stays in the left most position so the dash lights work when I need them. My phone screen makes better light in the cab to find the key hole than the tiny bulb through that little opening above the key.
1946 Chevy Pictures
1946 Chevrolet 2-ton. In family since new. Splash oiled 235, 4 speed main, 3 speed aux, single speed 6.17 rear. Original GM supplied 12' stake bed, paint on sideboards is still from the factory.
Ride Along Video!
Ride Along with a little load
Video Channel
32vld #1188131 10/25/2016 2:51 AM
Check the Jim Carters Truck Parts catalog, I think I recall they might have listed the switch in the past year to two? The somewhat triangular shaped bracket used on the 1/2 ton models to hold the throttle and choke cables in place behind the dash, has a hole used to hold the light bulb. This info may or may not be the same for the larger trucks???
