3 members (RLB, papas52, 1 invisible),
91
Mod | | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | Considering putting a '41 4 speed transmission in a '37 1/2T.
It appears that the universal joint from the '37 will not mate with the flange of the '41 transmission.
Question: Is the output shaft of the transmissions the same? Will the flange from the '37 3 speed slip onto the splines of the '41 shaft?
Unfortunately, we do not have access to the '37 3 speed flange today. Hence the question. If they won't fit we have to begin looking at other options.
Thanks for your time,
Justin | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Justin, My '37 half ton project came with a 4 spd in it, an option for that year. You can make it work with the correct u joint assembly.
My '42 half ton has the same 4 spd in it and I blew the u joint, tearing up the yoke that attaches to the output shaft of the tranny. I had a heck of a time finding a u joint assembly for that application and during the process inadvertently bought a u joint that fit the 3 spd. The out put shafts are different as the 4 spd has a larger beefier diameter. I am guessing it will be the same for your situation.
Look at Keith Hardy's Old Chevy Manual site, find the correct u joint part number and keep checking Ebay or your other sources for old parts. I think you will find one eventually.
Kent | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Justin, Below is a link to a u joint on Ebay that will fit a 4 spd in your '37 truck.
http://www.ebay.com/itm/Universal-U-Joint-Assembly-1937-1938-1939-Chevrolet-Chevy-Truck-GC-HC-JC-/311711388353?hash=item48937252c1:g:VmMAAOSwAuNW7Q5m&vxp=mtr | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 |
