| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | fj1947, I don't know that much about GMC's but if that was a Chevy I think its a LCF (low cab forward) but I'm not going to bet on it! Nice find and even better that the wife likes it. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | SWEET! Looks like you can't take that LF tire hunting! | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | Thanks guys, so this is a low cab forward truck? Shows how much I need to learn about these big bolts! Can you recommend a website that has some production info? BTW 69cuda someone also wrote "no trespassing" on one if the rear tires and painted the drive shafts like a barber pole jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think the model might be an F 350-8 or an FM 350-8 (8 for V8 engine) There was also a larger 370 model, and even larger LCF (Low Cab Forward - called COE in earlier years, pre-late 1955 Blue Chip GMCs) Spanky and others might know the difference in series letters/numbers. | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | That makes sense Tim because my serial number is F 354 8 T1071. Tag says 16,000 gvw & 32,000 gcw jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Low Cab Forward is a Chevrolet trademark name for what you have. GMC just called them the "F" series, they are technically not a COE as the cab is not over the engine. GMC actually never stopped making COE's from the 1930's up into the 90's. Chevrolet didn't make a COE from 1955-2 to 1959, they brought it back in 1960 as the Tilt Cab. Mike B  | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That is a really cool truck! Even better that the wife will go with you. Mine goes with me in mine sometimes and occasionally she will even drive it. | | |
