7 members (Otto Skorzeny, 1955 1 Series, Rusty Rod, baldeagle, dt235sd, Woogeroo, Hotrod Lincoln),
369
Mod | | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Thought I'd avoid waiting on Eastwood to ship me another quart of Rust Encapsulator, so I bought a quart of "Chassis Saver" at the Body & Paint Supply house locally. Didn't read the tiny print and got the stuff on my hands. Nothing will remove it now. I've tried laquer thinner, mineral spirits, MEK, Denatured Alchohol & Wash Thinner. Nothing works. I've got a formal function tomorrow night. Any ideas besides gloves? | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | try gasoline,but don't smoke. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Clint, I think I would seek "higher" guidance.  Honestly, if you have tried those items, it looks like it is insoluble after it dries. That means mechanical removal...freeze with an ice cube and scrape off. Try wearing a pair of nitrile mechanics gloves overnight...sometimes the sweaty hands syndrome will break the bond. Good luck...I hope your formal function isn't a marriage ..."who is this guy, a mechanic?". Stuart | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Hello dirty mit's,Iam using this new hand cleaner called cherry bomb!.it takes urathane even after its dried.another really good one is KUPRAN OR CUPRAN.see if you can find these in your area.good luck!!  | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Orbital sander might get it off. 80 grit  | | | | | Joined: Nov 2005 Posts: 2 Junior Member | | Junior Member Joined: Nov 2005 Posts: 2 | been reading articles on eastwoods panel flanger, don't like what i read, any body have any suggestions, I'll be using on the floor board on my 51 AD thanks | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Sounds like the impact of POR15. Here's what I've seen work: 1. brake fluid - haven't tried this on skin but I saw what happended when brake fluid sat on my POR15 painted frame. 2. baby oil - rub it in. it will work it lose. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Here's a chick trick. You need to mechanically remove it at this point. Go to the drug store and pick up some good "body exfoliating cream" or a decent "apricot" facial scrub (the kind with apricot seeds in the cream). These products do what the ladies call "exfoliate" the skin - polish the top layers away gently (no need for the 80 grit sandpaper).
This should work when the chemical options have failed. Good luck. Somebody's handle line here says something to the effect that if the ladies don't find you handsome they should find you handy . . . so those dirty mits aren't all bad (trust me on this)! | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | i would get some hand cleaner like i have. i got it at o'reilly's, it is gojo with pumice in it. it gets everything off of your skin, and leaves it nice and soft. http://automotive.gojo.com/products/product.asp?cat_id=16
2003 ford lightning 1959 chevy 36
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Harbor Freight has nice nitrile/latex gloves that are thick enough not to fall apart when wrenching. Use those next time.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2005 Posts: 3 Junior Member | | Junior Member Joined: Jul 2005 Posts: 3 | try some hand cleaner and just scrub with some 100 grit sandpaper. it might hurt a bit but if you need to get it off,you can get it off | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I hope no one gets the idea from this post that it is OK to use lacquer thinner, mineral spirits, MEK, etc. for hand cleaner. None of this stuff should be allowed to come into contact with your skin. Nitrile gloves are a must not an option when handling this stuff. The MSDS (material safety data sheet)for just about anything is available at this web page . For your health, look up any chemicals you may be using and heed the precautions. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | You dont say if you wanted to go to this formal function, sounds like the perfect out,stay home with yor bolt | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Clint's formal function was on the 5th. I wonder if he got that stuff off his hands. Come on Clint, come clean! HeHeHe  | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Yes, I went to the function and yes I got most all of the stuff off of my hands. Judicious and sometimes painful scrubbing with a nail brush and GOJO took 95% off. "Chassis Saver" is now in the trash and a new can of Rust Encapsulator is on the shelf. Cletis is right -- we should avoid using solvents to clean our skin, but desparate measures are sometimes needed in desparate situations. BTW, would you want to take communion on Sunday morning from a pastor with black gunk on his hands? LOL!?! I figured my congregations probably would not either. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Hey Clint - my dad is a minister who also administers communion - with clean if not unstained hands. Since he drives his hotrod truck to church every Sunday in the summer, the congregation just chalks it up to one of his eccentricities. So just show them your handiwork! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sometimes I use wd-40,, after it dries you might try sand paper,,Kim's idea sounds good,,, if all else fails,,, maybe in time it will wear off,, seems like that happens ,,,,,,,,,,,,,good luck...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2005 Posts: 8 Junior Member | | Junior Member Joined: Nov 2005 Posts: 8 | Sorry guys I hate to sound rude but I really have to laugh at all of this, I just went through all of this myself.
Dave
Livin like a rat.
| | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Try "Scrubs in a Bucket", A pretty good product. It works on tough stuff.
1941 AK named "PETEY" my buddy.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used to hate wearing disposeable gloves when working on cars, but now that Harbor Freight has double layer latex/nitrile gloves in 100 packs for less than $6, I buy those and use them for everything remotely greasy or icky. I used them doing some masonry work most recently. They are quite comfortable and tactile without tending to rip out like the single layer gloves do. Besides, being able to clean your hands with plain soap and water is great, and my hands don't dry out from the solvents. I even use them when using latex paint.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you absolutely can't wear gloves, the lanolin based "liquid glove" works ok, but probably would cause fisheye in a paint job.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I am wityh you 4/floor - I like wrenching but got tired of stained skin - plus any petroleum stuff this side of vasoline can't be good for you. I feel much better now that I keep that stuff off me and when I have to go to get a bolt or something at the store, pulling the gloves off and having clean hands ready to go is a huge help. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Try putting the nitrile gloves on and do something to work up a sweat. Maybe hold your hands over some boiling water as close and as long as you can. I wear those gloves everyday at work and in the summer when my hands sweat, they never look so clean. Your skin will have to let go of it, that stuff won't let go of anything once it's set-up, Good luck, Scott | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | There is NO Better hand cleaner that I have ever used than "Paint safe" available at NAPA auto parts stores and Sherwin Willaims part number PS90150
This stuff will remove urethane paint for goodness sakes. I have removed paint off leather shoes and a cloth jacket with it!
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Soap up your hands, then have someone add a spoonful of sugar to it. Sugar doesn't dissolve immediately, so it is like using sandpaper on your hands. Got this tip from a very old mechanic.
If that doesn't get it, add a little Comet or Borax to the mix.
This will chew your hands to pieces, so be careful how often you use it. I only use this method when I absolutely have to have clean hands - for a wedding or some other sorrowful occassion. | | | | | Joined: Jul 2003 Posts: 33 Apprentice | | Apprentice Joined: Jul 2003 Posts: 33 | Olive oil makes a good hand cleaner.  | | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Years ago someone told me to rub my hands with liquid dish soap and let it dry. This fills all the cracks in the skin. Also scrape a bar of soap with your fingernails it helps keep the grease out. This works well for grease but I'm not sure about other things. Of course wearing latex gloves is easier. | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Usually I just take a very long hot shower. the skin gets all prune like and then I fingernail or brush scrape it off the old dead skin comes with but no big deal. | | |
