3 members (Otto Skorzeny, baldeagle, 52Carl), 84 guests, and 2 robots.
Topics128,130
Posts1,056,714
Members48,454
Does anyone have any input on duel carbuerator setups? I have a Fenton setup with 2 Rochester B's. Tomorrow I'm going to install them, any tips and where's the best place to get stainless steel or steel fuel and vacuum lines locally?
Scott
Chevytruckdaddy
Most of us who run dual setups make our own fuel lines. SS will be harder to fit due to the tight bends and double flares, but it can be done with the proper tools.
I am guessing your carburetors are a matched set? with matching ID numbers and internal metering? If not, better start again, they must match due to the large number of variations in the Model B. Off the shelf rebuilds usually don't work, since rebuilders mix and match parts, thats why you won't find number tags.
Joe
Plumb them with rubber lines- - - -it will be easier to switch back to original when you figure out you've got one too many carburetors.
Hi Joe, thank you for the reply... Yes my B's match and I rebuilt them myself. My local Carquest store had the lines I needed to plumb the carbs. As soon a I get them up and running I'll post the results.
Scott
Chevytruckdaddy
Quick question, do I run a choke cable to both carbs or just a chock cable to one carb?
Chevytruckdaddy
I have successfully done one cable and two cables (chokes). Take the choke plate off the non-choked carb.
What year/size engine?
What year/engine carbs?
Thank you Tim
Chevytruckdaddy
I did both chokes on the W-1 set up I did. Much better in the cold New England winters.
I buy a choke cable from a British Triumph sports car.
Most of the imports in the 50's and 60's ran dual carbs and developed various ways to run cables. The Triumph has a single knob and splits into 2 cables behind the dash. Simple installation, just replace the knob with the Chevy one.
I switched to dual carbs and love the way engine runs. Send me you number and i will text you pictures of fuel line set up i used.
Paul. 828-446-4282
ODSS Lawman
ODSS Lawman
Important to get two EXACT carbs. Same jets, make, model, etc.
Get a unison tool to make them play nicely together.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
