4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#1180878 09/02/2016 10:12 PM
My 1950 216 did not have an oil shield covering the front engine mount. Where these shields used on all 216's? Everything I have seen says it should be there. I've ordered one already expecting it should be there!
Jackie
Since the only time these engines quit leaking oil is when they're empty, it makes sense to deflect the leakage away from the rubber in the front mount. Harleys and Detroit Diesels do the same thing! Good call!
Jackie, I can't answer your question with a perfect knowledge but I've seen a few over the years, including a few 1950's and all I've seen had the cover....but I haven't seen them all.
Check Jim Carter Truck Parts
The problem with the oil shields is that they are thin sheet metal and get beat up pretty good after a while and wear through, allowing oil to pass through them.
Carl
Carl
Does that occur when the rubber breaks down?
I have never seen that, but I bet the rubber could get banged-up and deteriorate quickly if the bolts are not snugged up every so often?
I think you've got it right Tim. The originals probably went bad pretty quick due to the type of rubber used. Once the rubber flattens out, you will have metal-to-metal contact where a gap is specified between parts. Once that happens, the bolts aren't tight anymore and everything gets the jack hammer treatment.
I am very surprised someone has not come up with a better aftermarket design of the entire mount. Its not like its a part anyone can see once installed.
Carl
Fox Offline
Speaking of this oil shield. Does the lip on it curve down and over the mount? Facing front or rear?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
My shield doesn't have a lip. It is basically a simple rectangular box, bottom side open, top side has 2 dimples and 2 holes for the nuts and bolts.
http://www.stovebolt.com/techtips/engines/motor_mount_front/1.jpg
It has been my experience that the oil runs along the shield and down through the bolt holes. Personally I think the part is useless.
1951 1 Ton Completed
On top of the oil shield being pretty much useless after a short time, the after market ones have square edges front and back (the originals are radiused), making it difficult to change the fan belt.
