4 members (52Carl, klhansen, 2-Ton, Wayne67vert), 101 guests, and 1 robot.
Topics128,113
Posts1,056,614
Members48,450
I'm back on my '54 project. I'm pretty sure which connections on the block feed the filter/oil gauge and then the return.I want to be positive about the connections on the original filter that I got with the project. It has three , 1/8" ports. I believe the top [side] is the inlet, I am thinking the lower [side ] is a drain. the bottom [center] outlet returns the oil to the engine.It will be firewall mounted, since the fenton manifold won't accept it. Will someone here let me know if I am on the right track OR straighten me out. Pictures help, if you can.
John Baker
Sounds right to me.
•1952 Chevrolet 3800 pickup
---All pictures---
JB
Thanks a lot. It Helps.
John B,
