0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#1176728 08/04/2016 2:49 PM
I hope to finally have my '59 on the road in a week or so. Because I have a non-stock rear end and a T-5 I want to install a tach. I haven't seen or heard any rpm figures for redline or shift points.
I'm running a stock 235 with dual exhaust.
Recommendations?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
what rear end do you have, I dont th ink your redline would be super high with a 235.. tachs are nice, had one on my 52
it had the 235, with a t-5 but a high way rear gear, like 2:73
never used the tach for shifting, just the sound of the engine,
mine had fenton headers, dual exhaust, 858 heads, pretty quick
but I did fine by just shifting as normal and not worrying about a red line, I would think the red line might be low 4........happy trucking..
Redryder pix
My Hotrod
3:42 rear end. Also have Fentons. Don't know what my final is in the T-5.
I don't expect quick, just want decent highway speed.
Ex Hall Monitor
Ex Hall Monitor
My '38 can run 60 all day with the 3:73. You should have no problems at all driving highway speeds. This graph shows an engine speed of 3300 RPM @ 70 MPH with a 1 to 1 final drive ratio & the 3:73 rear end.
Your ear will tell you things long before the tach does
