4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#1176219 07/31/2016 3:08 AM
Getting ready to tackle replacing my center support bearing on the driveshaft. Do you press it on or hammer it on with a pipe?
1953 GMC 1-Ton Pickup with 350 and 700R4
Either way just make sure your on the "race" and not the bearing when putting it on. Some go on easy....some not so easy. Good luck.
If you have a driveline shop nearby take it to them that's what I did. Pressed old one off pressed new one on, 5 minutes, $5, although that was about 20 years ago!
51 1 ton Panel
Betty, she's a handful
The manual is helpful.
The bearing fits in a rubber sleeve/cushion and is pressed in the hanger/bracket.
1952 Chevrolet 3800 pickup
---All pictures---
I went with a modern style bearing assembly.
Z
hmmm.
hmmm.
Z Offline
I cut a strip of mud flap from big rig back in '82. I fit it right in place of the old rubber sleeve. It sill works great.
The old one slid right off and the new one slid right on. I bought a modern SKF bearing assby from RockAuto and had to add a 1.5" spacer and open up the bolt holes on the frame. Working good.
