| | | Forums66 Topics128,089 Posts1,056,433 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | any thoughts on how to remove steering wheel on a 46. I have the button off but what next?? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I can,t remember. Are there two threaded holes in the steering wheel near the shaft? If so you use a steering wheel puller. A cross bar with three bolts. Two thread into the steering wheel the third is threaded through the cross bar and tightened until it pops the wheel loose. If not have a friend pull up on the wheel while you give the center shaft a good wrap with a hammer. Leave the nut on at the top of the threads to protect the threads. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Maybe, maybe not....but I have left the nut threaded on even with the shaft to protect the shaft, then slid down in the seat till I could get my knees under the steering wheel then push upward whack it in the center with a hammer at the same time. Has worked for me many times when I couldn't afford or borrow a puller. ...I'd squirt a little penetrating oil down around the shaft and let it work for a few minutes. | | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | There should be two small holes for a puller. The '37 uses 10-32 threaded screws, so I had to make a puller out of some 1/4" steel strap and a 3/8-16 center bolt. I still use Alvins method once I get some pressure on the puller. The 10-32 screws don't like a lot pressure on them. I found allen head screws are a lot tougher and can take more of a beating.
Joe | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Using Alvin's process has removed 99% of the wheels I've had to remove in my time. The other 1% I had to borrow a puller.
