1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Hello....
My 64 k10 with 283 v8 doesnt want to start after I've run the engine for a while. This is especially true in the summer months. If I drive to town, I have to wait at least 15/20 mins for the engine to cool before it starts over. If I try any sooner, the truck just tries to turn over with no luck.
Looking for some help understanding the problem and how to correct. I find myself leaving the truck running when I'm doing short errands because I can't count on it starting after a few mins.
Thanks in advance. John.
1964 K10 Fleetside Pickup Truck
Sounds like a vapor lock to me through there are several other things that might cause it. I solved my vapor lock problem by installing a low pressure electric fuel pump near the gas tank on a spring loaded toggle switch. I'm sure others will have other solutions.
If the timing is correct then I'd look at the ground, starter and battery. With it hot and the compression still on the engine all the above must be good.
Big Bolt Forum Moderator
Do you mean it just spins and won't start, or that it acts like a dead battery? If the former, as Achipmonk and beltfed said, it sounds like fuel and/ or timing. Not sure which carb you have, if an edelbrock or carter, they can get hot and "boil over" and tend to flood th engine right after you shut it down. Pop the air cleaner off and look down the carb throat when it is real hot right after you shut it down and make sure it is not wet and dripping gas down the carb.
If the latter (acting like a dead battery) then it could be battery, cables, starter, or even may need a heatshield between starter and exhaust. My Suburban used to do the same thing when it got real hot, headers would heat up the starter and when real hot, acted like a dead battery. I added a 2nd 6 ga ground wire from battery to frame (had a spool of 6 ga and ends on the shelf) and made sure everything was clean.
Mike
Carburetion specialist
If the engine spins but no start, try this link:
http://www.thecarburetorshop.com/Troubleshooting.htm#Hardstarthot
Jon.
The Carburetor Shop
Thanks guys. This was very helpful. After reading the thoughts about the gas, I decided to add no ethanol gas and followed the instructions in the link Carbking provided and the truck has started each time. I turn the engine over for a few seconds and then stopped. Pressed on the gas pedal about a third of the way and turn the ignition and she turned over.
I have a phenolic space between the carb and the manifold. That should help.
The carb is a Rochester 2 barrel.
Regarding the heat shield on the starter...any thoughts on what to do there? I don't want to replace the starter. Though a friend of mine thought I should instal a mini high torque starter.
