0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | On part of the the edge around the inner fender there is a 1" wide strip of what looks like heavy roofing paper attached by "staples". I have plenty of this material on hand and need to know the best way to attach it. Would some type of strong glue like Liquid Nails work? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I've be trying to find out what that "heavy roofing paper" is. Care to tell us? Thanks
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I believe it is best to loosely attach it before assembly. It will form to fit and hold itself in place once things are bolted together. It is for anti squeak. I have never found staples that perfectly match the existing holes so I cut short lengths of steel wire (stainless if you have it, but not necessary)that fit through the hole diameter and bend them to fit. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I've be trying to find out what that "heavy roofing paper" is. Care to tell us? Thanks Ummm... it's roofing felt... I used 30# but you could double up 15# and get there too. Or maybe cut up a bunch of those plastic cutting mat/boards. The thin stuff. That would really non sqeek.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | My question is, since the paper is stapled on, won't you then have metal to to metal contact since the staples are big and outside of the surface of the paper? I am positive that these trucks were originally put together this way. I just don't understand why.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I parted ways with orthodoxy when I came upon that same question. Metal on metal seemed ill advised and I reason things like staples were assembly line needs not the trucks.
I'd probly use plumbing adheasive over liquid nails but a color coded volcum caulking would be trick...
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | CASO, what is volcum caulking/ Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Jim, you make a good point. Maybe I'm over thinking this. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Had to find a 'proper' name for it... Butyl or rubber caulking.
I just used the name I learned for it way back when.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks CASO, that narrows it down a bit. I don't think I have ever used it. | | |
