2 members (Nick in Manitou, 1 invisible), 60 guests, and 1 robot.
Topics128,049
Posts1,055,679
On part of the the edge around the inner fender there is a 1" wide strip of what looks like heavy roofing paper attached by "staples". I have plenty of this material on hand and need to know the best way to attach it. Would some type of strong glue like Liquid Nails work?
I've be trying to find out what that "heavy roofing paper" is. Care to tell us? Thanks
I believe it is best to loosely attach it before assembly. It will form to fit and hold itself in place once things are bolted together. It is for anti squeak.
I have never found staples that perfectly match the existing holes so I cut short lengths of steel wire (stainless if you have it, but not necessary)that fit through the hole diameter and bend them to fit.
Ummm... it's roofing felt...
I used 30# but you could double up 15# and get there too. Or maybe cut up a bunch of those plastic cutting mat/boards. The thin stuff. That would really non sqeek.
Give me ambiguity
or give me something else
My question is, since the paper is stapled on, won't you then have metal to to metal contact since the staples are big and outside of the surface of the paper? I am positive that these trucks were originally put together this way. I just don't understand why.
I parted ways with orthodoxy when I came upon that same question. Metal on metal seemed ill advised and I reason things like staples were assembly line needs not the trucks.
I'd probly use plumbing adheasive over liquid nails but a color coded volcum caulking would be trick...
Give me ambiguity
CASO, what is volcum caulking/ Steve
Jim, you make a good point. Maybe I'm over thinking this.
Had to find a 'proper' name for it...
Butyl or rubber caulking.
I just used the name I learned for it way back when.
Give me ambiguity
Thanks CASO, that narrows it down a bit. I don't think I have ever used it.
