8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall), 122 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#1172016 07/01/2016 5:08 PM
I got the remote master cylinder reservoir from Brothers. I can not figure out where to put it,or how. How is everyone doing this. I run a 235 ith 4 0n the floor so I can not obstruct the brake and clutch levers, and it just isn't the right shape to mount just above the master cylinder conversion bracket so as to place it in the original master filling spot.
I've seen them mounted on the firewall where a firewall-mounted master cylinder would go.
ditto what Echo says. On the firewall. Most of them are kind of small anyway and shouldn't be a problem or in the way.
I like this guys option.
Under seat option
Sir Searchalot
Sir Searchalot
You can buy a VW style or Passat firewall mount dual reservoir for $13-$25 and add inlets to a stock MC lid. Beats $110 plus ship.
I like your style,I had a VW Bug one in mind, it would beat the heck out of the rigmarole of topping up when bleeding brakes etc.
I just haven't got round to it yet.....
The only issue I haven't addressed is on my M/C,the gasket is a one piece affair that covers the whole of the top of the reservoir,i'm not sure if it would be OK to open it up to allow fluid entry from the cover.
More pix on Flickr.
Sir Searchalot
Sir Searchalot
Sealing is the issue on remote. The aftermarket kits still uses a bail to hold the cover but have a thicker gasket. Look at pictures of their kit. Gasket is open in the middle. The MC will always be full all the way up to reservoir, so a good seal is No. 1. I really don't see why there has to be a dual remote, two hoses running down to MC. The two MC chambers will flow into each other?
Good point.
More pix on Flickr.
